Go to Post The "line" is the point at which we've raised the floor so high that the advanced teams are hitting the ceiling. The ceiling is pretty darned high (and the GDC keeps raising it), so I don't think we're in danger of that any time soon. - EricVanWyk [more]
Unread 24-01-2007, 12:01
Bob22341 Bob22341 is offline
FRC #1870
Bob22341 will become famous soon enough
Re: Problem with program uploading
I have the same problem. I have tried suggestions in this thread, and others besides without any success. When I loaded the software for the first time, I just loaded the program and didn't load any firmware. Was I supposed to? I am now not able to erase the code that was downloaded, and the good downloaded code doesn't work, giving program errors. Can anyone help me?
Unread 24-01-2007, 13:14
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
http://www.ifirobotics.com/docs/lega..._2004-1-14.pdf
http://www.ifirobotics.com/docs/rc-r...-6-13-2006.pdf
When we have difficulties, we start at the beginning. Might seem silly, but it helps tell us what is working and what isn't.
1. Using the ifi loader 1.1.0 (http://www.ifirobotics.com/docs/ifi-loader-v1-1-0.zip) reload the master code and default hex code. Instructions can be found in a pdf file within master-software-ver11.zip/. Only use the pdf file in this zip file - use the V13 master code as outlined below. This should be done on the 2006/2007 controllers only as I am not sure what will happen - if anything - if this is tried on a 8520 processor in the 2005 controller.
. V13 master code is available in 2007 default code (http://www.ifirobotics.com/docs/frc-code-2007-8722.zip, the filename is FRC_MASTER_V13.BIN
. FRC_Default.hex is in the same zip file and is the default hex file to use
. Make sure you select the correct COM port via "PortSettings" menu in ifi loader.
. Follow ALL directions in the pdf instructions, including re-verifying the controller type. If the ifi loader already shows "FRC" where expected, do another verification to start anyway. If we can't get controller verification then we know we have either a communication setup issue with our COM port or a bad controller. Its always been a COM port setup issue if we cannot get through controller verification.
** If we get through this cleanly, then we know it isn't a problem with the COM port or controller **
2. Using MPLAB, compile and download unmodified default code [which we keep in a separate directory]. The default code is in the aforementioned zip. Make sure that you select the "Configure -> Select Device" appropriately. For 2006/2007 this is PIC18F8722. For 2005 controller's (that haven't been sent back to be upgraded) this is PIC18F8520.
. build all ("Project->Build All") so that a new .hex file is created without errors
. startup ifi downloader V1.1.0, select the hex file just created and download.
** If there is a problem at this point, it is somewhere in the configuration setup of the MPLAB environment. Typical problem has not been selecting the correct PIC chip device as the target for the build or not having MPLAB properly configured. MPLAB and C18 Microchip suite was provided in KOPs. **
3. Now on to EasyC. Using provided .bin and .hex files in step 1 we've proved that the COM and controller are setup properly and can be communicated to ok. This means there is an EasyC setup issue if we still cannot download from here. Try the above steps and report explicit good/bad results. By then I'll be home and have access to EasyC and will update the steps for EasyC in this post. ;-)
Please be explicit as there has been a lot of advise in this thread.
Q. Were you able to verify the controller under the IFI loader?
Q. Were you able to download the master (bin) code without error?
Q. Were you able to download the default (hex) code without error?
Q. Were you able to build this year's MPLAB default code without error?
Q. Were you able to download this year's MPLAB default code without error?
Unread 24-01-2007, 14:18
FRC #1870
I have followed all of the documenation on verifying the controller port, and the controller verifies, but when I try to download master code and click on the download button, there is suddenly no controller to download code too.
Unread 24-01-2007, 15:40
FRC #1870
Problem Solved
Controller returned for warranty work.
Unread 24-01-2007, 15:42
AKA: Bud
"there is suddenly no controller to download code to."
Out of curiousity, how did this manifest itself? Was there an error or did the download just hang or was there some other symptom?
thanks.
Unread 25-01-2007, 07:20
1573's Avatar
1573 1573 is offline
FRC #1573 (KGSTARS)
1573 is an unknown quantity at this point
Send a message via ICQ to 1573
when im trying to upload the program to the controller the computer isent recognizing the controllers version (2006/2007 controller).
but it does recognizes the 2005 controller
Unread 25-01-2007, 14:15
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Rookie Year: 1999
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Sounds like it may be the same problem I had with the actual controller. I tried our 06 RC and worked fine then tried the 07 and wouldnt work. I called IFI and he went through all the steps everyone on here did and told me to send it in and they'll check it out. I am wondering if part of the processors are goofed up or the actual program input interface.
Oh well now I just wait a few more days to get it back.
-Mike
Unread 26-01-2007, 08:56
1573's Avatar
FRC #1573 (KGSTARS)
YAI, ok i found the problem.... i tried 3 computers then i tried at home and its works correctly there so the wole problem was the 3 computers. thank you guys for the help
Program Build Problem douglass1371 Programming 3 18-02-2006 18:46
HELP needed, problem with streamling, need uploading space or diffrent solution... Nimmy General Forum 5 15-02-2006 11:18
program download problem zdeswarte Programming 5 23-03-2005 06:46
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
