Go to Post From past experience members of our team insist on never trusting gravity. - Vash [more]
Unread 08-01-2007, 13:07
brennerator brennerator is offline
brennerator is an unknown quantity at this point
Difference between user_routines
What is the difference between user_routines.c and user_routines_fast.c?
Also, how do I generate hex files in FusionEdit?
Unread 08-01-2007, 13:19
Matt Krass's Avatar
Matt Krass Matt Krass is offline
"Old" and Cranky. Get off my lawn!
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Matt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond repute
Send a message via AIM to Matt Krass
Re: Difference between user_routines
Generally speaking the functions you would edit in user_routines.c (Such as default routines) loop at a specific rate (26.2 ms) where as functions such at Process_Data_From_Local_IO in user_routines_fast.c run as fast as the chip can process them, while managing everything else.
Matt Krass
If I suggest something to try and fix a problem, and you don't understand what I mean, please PM me!
I'm a FIRST relic of sorts, I remember when we used PBASIC and we got CH Flightsticks in the KoP. In my day we didn't have motorized carts, we pushed our robots uphill, both ways! (Houston 2003!)
Unread 08-01-2007, 15:22
Davx's Avatar
Davx Davx is offline
Davux
AKA: Dave Amenta
FRC #0195 (Cyber Knights)
Davx will become famous soon enoughDavx will become famous soon enough
Send a message via AIM to Davx Send a message via MSN to Davx
brennerator : Read the comments in main.c, user_routines.c, and user_routines_fast.c. Know that statusflag.NEW_SPI_DATA will equal 1 once every 26.2ms. The functions in user_routines_fast are generally for interrupt handling and fast loops. Understand how the structure works before you start programming, otherwise you'll end up with some strange problems that are completely avoidable.
--David Amenta - Dave Amenta .com - Person Meets Profession
Number of lines of code in user_routines.c teh_pwnerer795 Programming 12 01-01-2007 09:10
Strength difference between aluminum sdcantrell56 Technical Discussion 3 21-01-2006 10:07
What is the Difference between Parker and Bimba generalachoo Pneumatics 3 23-01-2005 16:58
Difference Between Motors shyra1353 Motors 4 13-01-2004 10:12
Difference in aluminum archiver 2001 1 23-06-2002 23:49
