adding swiches to O/I
Can i add some swiches or another joystick to the O/I controller??
Re: adding swiches to O/I
yes yes you can. go download the pin out guide from IFI and that should help you figure out how to make a custom UI.
refrence guide page 6 should be helpful to you Last edited by Stuart : 08-01-2007 at 16:04. Reason: adding link |
The Blue Alliance did an episode on custom controls. If you watch it, we explain how you can wire your own custom controls (including modifying an Easy Button!).
We also have show notes (pdf) for the episode, with schematics of how to wire up your own controls using switches and potentiometers. Check it out, I am pretty sure it will show you exactly what you want. |
| Adding to pneumatic piston | oaktown1188 | Pneumatics | 2 | 14-02-2006 12:11 |
| Adding Code | haywirerobotics | Programming | 2 | 18-01-2006 07:04 |
| Adding objects | Matthew_H | 3D Animation and Competition | 5 | 12-02-2004 19:33 |
| Adding RAM to RC | archiver | 2001 | 1 | 24-06-2002 00:59 |
| Adding my Thanks | archiver | 2000 | 0 | 23-06-2002 22:57 |
