Go to Post Holy 5-year-old-thread-revival Batman!! - Mr. Freeman [more]
Go Back   Chief Delphi > Other > VEX
Unread 08-01-2007, 18:22
Dmkaz Dmkaz is offline
Dmkaz is an unknown quantity at this point
Send a message via AIM to Dmkaz
SetMotor Code Problems
I have been working on the code for a holonomic drive system for some time now and when it hasn't been working, I always thought it was something to do with the code, now I'm starting to beleve not.
The problem seems to be happening when I throw in a SetMotor block into the loop. I've done print screens to make sure the value is comming back correctly, but when I put in the SetMotor block, 1. the drive motors start acting sparatic, not just the one I am calling to but ALL 8 outputs on the reciever. Also, I am getting no input from the controller at all. The reciever is not showing the controller is even on.
Here is the following code I am using...
Code:
#include "UserAPI.h"
unsigned int blah;
void main ( void )
      while ( 1 )
          blah = GetRxInput ( 1 , 1) ;
          PrintToScreen ( "%d\n" , (int)blah ) ;
          SetMotor ( 1 , blah ) ;
Unread 13-01-2007, 07:37
WindTech WindTech is offline
AKA: Mitch Thompson
FRC #0481 (The Hitchhikers)
WindTech will become famous soon enoughWindTech will become famous soon enough
Send a message via AIM to WindTech
Re: SetMotor Code Problems
Did you update all the firmware on said controller?
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
GTS code Problems caderader Programming 8 13-02-2006 19:23
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Code problems doyler Programming 14 15-02-2005 16:23
