| View Poll Results: What is the approach angle of your ramp (floor to ramp) | |||
| < 10 degrees |
15 | 10.00% |
| 10 to 15 degrees |
36 | 24.00% |
| 16 to 20 degrees |
65 | 43.33% |
| 21 to 25 degrees |
21 | 14.00% |
| 26 to 30 degrees |
9 | 6.00% |
| > 31 degrees |
4 | 2.67% |
| Voters: 150. You may not vote on this poll | |||
Re: Ramp Angle Survey
Forgive me if I'm wrong, but does it really matter whether the robot is up past the ramp. It doesn't have to be past the corner at the top of the ramp to earn points, it just has to be at least 4 inches up the ramp. So in a worst case scenario, just make it so that your robot can make it that far up a ramp and then turn a little sideways so that they don't roll back down. Viola!
Many robots will roll when powered down. You'd have to turn sideways to be sure you don't roll. Do you want another robot turning atop yours? I don't We are thinking of an 8" tall robot with a 36" long ramp, Sin (8/36) = ~13 degrees. Don |
Hopefully 10- 15 degrees. This is half the angle that last year's ramp was so it might be easier to get up
Check out this post to use a spreadsheet I created a while ago to figure out ground clearances: http://www.chiefdelphi.com/forums/sh...ound+clearance You will see that with a 30" wheel base you can actually tolerate a 15 deg hump transistion if you have 2" of ground clearance. |
-Nick/1334 |
We have about a 19 degree angle. We're a shorthanded rookie team, so we thought it would have been easiest. The robot itself is only going to be about 13" tall, I believe, so we fit the 12" high bonus.
We're hoping to be having a ramp on the front of our robot, folding out to the sides. It will be 28" wide (so it will leave 10" of our overall length), will have a ramp fall of one side, then a platform with a 90 degree support fall off to the other. Then, we're going to try to mount an arm in the 6" we have left at the end of our robot for scoring tubes, with the arm being on the opposite side of the robot at the end of the match so our partners won't hit it.
Because of the design, we've decided what we're actually building is an aircraft carrier. Right now we're considering adding side rails to help guide partners, and possible runway lines or a bullseye for artistic value. |
#10
| Motor Ramp Up/Ramp Down Function | Tom Bottiglieri | Programming | 12 | 03-12-2006 23:31 |
| To ramp, or not to ramp? | phrontist | Rules/Strategy | 27 | 26-01-2006 17:56 |
| Angle of Launcher | ThisGuyRight | Rules/Strategy | 3 | 24-01-2006 11:05 |
| Angle from X,Y | Astronouth7303 | Programming | 18 | 19-04-2004 22:08 |
| The angle of going up the Ramp | David Bryan | Programming | 2 | 21-01-2003 20:56 |
