Go to Post Battle Bots and other robot fighting competitions is to First Like McDonalds to Hamburgers They get the idea, and have the taste, but they are bad for you in the long run. - Conor Ryan [more]
Unread 09-01-2007, 01:19
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Inflating the Ringers
There are lots of ways to inflate the ringers, but I forgot the air mattress pump at home and didn't want to subject the team to mass huffing and puffing... and didn't have a nice connection to fit up to the shop's compressor system... so I was stuck.
Then I pulled a piece of tubing off one of the cylinders on an old robot... fired up the pneumatics system and stuffed the end of the tube into the valve on the ringer. A perfect... albeit a bit tight... fit.
The robot can inflate the ringer. How cool is that?
Jason
Unread 09-01-2007, 23:07
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
Team Role: Mechanical
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Re: Inflating the Ringers
We used the same technique to inflate ours
Championship - Delphi "Driving Tomorrows Technology"
Unread 09-01-2007, 23:38
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Jason
You don't need a special connection to fill it with a shop compressor nozzle. Assuming you're using a nozzle that has one of those conical rubber fittings on the end. Just stick it in the valve and let it rip.
2001-2004: Team 100
2006-Present: Team 254
Unread 09-01-2007, 23:39
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
famous last words!
Unread 10-01-2007, 17:08
Zero-Bee's Avatar
Zero-Bee Zero-Bee is offline
Havin' a gas gas gas.
AKA: Andrew Page
FRC #0836 (RoboBees)
Team Role: Leadership
Zero-Bee is a jewel in the roughZero-Bee is a jewel in the roughZero-Bee is a jewel in the roughZero-Bee is a jewel in the rough
Send a message via AIM to Zero-Bee Send a message via MSN to Zero-Bee Send a message via Yahoo to Zero-Bee
Originally Posted by squirrel View Post
famous last words!
lulz.
I just do alot of... huffing and puffing. >->
FRC 2007 - It's gonna be a gas gas gas.
Unread 10-01-2007, 17:39
mcmouse mcmouse is offline
FRC #0451
mcmouse is an unknown quantity at this point
Question Re: Inflating the Ringers
Has anybody seen rules about how much the rings have to be inflated. (e.g. a psi value like for your care tire.)
or just blow them up untill the 'feel' right?
JS
Unread 10-01-2007, 19:43
sphinx sphinx is offline
FRC #1040
sphinx is an unknown quantity at this point
I just blew ours up. It takes about 2 minutes, it's really not a problem.
Unread 11-01-2007, 12:23
Libby K's Avatar
Libby K Libby K is offline
Always a MidKnight Inventor.
FRC #1923 (The MidKnight Inventors)
Rookie Year: 1992
Libby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond repute
Y'see, 1923 blew up our ringers by hand. It's called the "who has the most lung capacity" method. It takes a little bit longer, and it's WAY less cool, but it works.
Libby Kamen
Team 1923: The MidKnight Inventors
2006-2009: Founder, Captain, Operator, Regional Champion.
2010-Always: Proud Alumni, Mentor & Drive Coach. 2015 Woodie Flowers Finalist Award.
229: Division By Zero / 4124: Integration by Parts
2010-2013: Clarkson University Mentor for FLL, FTC & FRC
FIRST Partner Associate, United Therapeutics
#TeamUnither | facebook, twitter & instagram | @unitherFIRST
questions? comments? concerns? | twitter: @libbyk | about.me/libbykamen
Unread 11-01-2007, 13:40
MrForbes's Avatar
AKA: Jim
we inflated the rings with "lung power", and later measured the pressure to be well under 1 psi, far from fully inflated.
Unread 11-01-2007, 23:02
MrForbes's Avatar
AKA: Jim
Today the students inflated the rings to 2.5 psi, using the compressor from last year, a T fitting, and an old auto tuneup vacuum/pressure gage.
We all noticed quite a difference in how the rings behave on the test rack, and the size increased enough that our first design test manipuators didn't work on them.
Unread 11-01-2007, 23:24
efoote868 efoote868 is offline
foote stepped in
AKA: E. Foote
FRC #0868
efoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond repute
my team had a race between lung power and compressed air. We actually tied... It took 10 mins to find an appropriate nozzle to the school's compressed air system... once we found it, it took about, oh, 45 seconds. The kid who blew it up was huffing and puffing long afterwards...
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 11-01-2007, 23:43
MrForbes's Avatar
AKA: Jim
I was asked about the type of gage we used for measuring ring inflation pressure, and how it can be connected to the tube. Here is a similar gage sold by Harbor Freight, it includes some adapters to fit whatever size hose you have, or to fit in the ring inflation hole.
Unread 10-01-2007, 21:03
Zero-Bee's Avatar
AKA: Andrew Page
JS
I don't belive there is anything specific. Just get it feeling right. As long as it's relativly smooth, you should be fine.
Unread 10-01-2007, 21:24
Mr.G Mr.G is offline
AKA: Kevin
FRC #0326 (Xtreme Eagles / Romulus High School / General Motors)
Mr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond repute
Send a message via AIM to Mr.G
The tube is supposed to be inflated to 2.5 psi.
Here is the info and ordering information for more.
http://www.usfirst.org/community/frc...t.aspx?id=4060
  #15   Spotlight this post!
Unread 12-01-2007, 09:22
Lindsey Lindsey is offline
FRC #0862 (Lightning Robotics)
Lindsey will become famous soon enough
From the link MR. G posted:
"The maximum inflation for these items is 2.5 psi; the actual FRC-Competition specifications will be provided soon."
2.5 PSI is the MAX not necessarily what FIRST will be using on the field.
-Lindsey
vex ringers colin340 VEX 8 11-01-2007 16:41
Knocking down opponents ringers Caseavong Rules/Strategy 6 08-01-2007 17:43
32in Ringers D.Stephenson Kit & Additional Hardware 1 07-01-2007 10:19
Ringers Branden Ghena Kit & Additional Hardware 8 06-01-2007 18:33
Inflating Robots =Martin=Taylor= General Forum 6 30-06-2006 13:16
