Go to Post Not even close to ready...can we delay it till like...January 2010? - Cory [more]
Unread 09-01-2007, 11:22
dez250 dez250 is offline
54... What a good number!
Rookie Year: 2000
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
FIRST 2007 GUIDELINES, TIPS, & GOOD PRACTICES
FIRST has posted the 2007 FRC Guidelines, Tips and Good Practices paper. This 38 page packet includes many points of notice and interest, Specs of information and even a well documented list of suppliers with contact for them. I would suggest to everyone to take the time to read over this document as it does include many things ranging from complete motor specs for this years kit, to the wiring diagram for this years signal light. Below you will find an index breaking down this packet and what each section covers.
Code:
G 2007 FIRST Guidelines, Tips, & Good Practices...............2
G.1 General........................2
G.2 Conventions................................2
G.3 SAFETY................................................2
G.3.1 General Shop Safety:.................2
G.3.2 Robot-Specific Safety:.........................3
G.4 Kit of Parts.................................................4
G.5 The Robot - Mechanical.........................................6
G.5.1 General............................................................6
G.5.2 Building the Chassis................................7
G.5.3 DC Motors...........................................................8
G.5.4 The Drive Train........................................11
G.5.5 Miscellaneous.........................................15
G.6 Robot Electrical.............................................16
G.6.1 Building the Electrical System..........................16
G.6.2 12V Power System Overview...............................19
G.6.3 Motor Power Distribution...............................21
G.6.4 Sensors....................................................24
G.6.5 Custom Circuitry..................................27
G.6.6 The Robot Controller....................................27
G.6.7 Operator Interface....................................31
G.7 Robot Pneumatics............................................34
G.7.1 Component Definitions......................................35
G.7.2 Pneumatic Electrical Distribution..........................36
G.7.3 Using Vacuum on the Robot.............................37
G.8 The Final Touch..................37
G.8.1 Signal Light.....................................................37
G.8.2 The Flag Holder.......................................38
G.8.3 One Last Look..................................38
-Michael Dessingue
Unread 09-01-2007, 11:51
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
Re: FIRST 2007 GUIDELINES, TIPS, & GOOD PRACTICES
I found this very usefull, and im glad FIRST put this out because everyone needs a reminder once and a while.
Min-Max to the Max!
Unread 09-01-2007, 12:02
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
As a general reminder, be aware that the GTGP document isn't a part of the rules. If there is a contradiction, the rules will be enforced.
Also, there's a quirk in the specifications for the F-P motors (9012) in both the 2006 and 2007 GTGP documents: maximum power is given as 387.5 W, but if you look at FIRST's 2006 spec sheet for that motor, that's in fact the electrical power drawn (Wi), not the mechanical power output (Wo = 171.0 W). (The difference is because of the 44% efficiency at that point on the power curve.)
By way of comparison, the other motors are listed in terms of mechanical power. (I just verified the FR801-001 small CIM has Wi = 698.4 W, and Wo ≈ 337 W, as listed, and I think the others are similarly denoted.) So be aware what's what, when you're designing things.
Unread 09-01-2007, 20:26
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
In addition to Tristan's notes, this document incorrectly labels the 36mm gearbox as being 16:1, when it is actually 64:1. This could make a huge difference in your design, so be aware.
EDIT: Also, the numbers in this document for the RS-540 vary by 10-20% from the numbers on the Banebots website. YMMV.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
paper: FIRST Publicity Tips Mark McLeod Extra Discussion 0 19-05-2006 10:01
Fantasy FIRST drafting tips for newbies (and veterans) Koko Ed Fantasy FIRST 18 20-04-2006 17:06
Extending 6 Gauge Wire - Best Practices? Mr. Lim Electrical 7 01-02-2005 02:03
YMTC: Bluateam practices before Magnolia Regional Natchez You Make The Call 3 08-01-2005 18:51
Taking pics at FIRST events... Tips needed MattK General Forum 17 10-03-2003 22:33
