Go to Post You really can't have a bad year. The only way you can is to come out of it and not learn anything. - Dan Petrovic [more]
Unread 09-01-2007, 12:37
K.Porter's Avatar
K.Porter K.Porter is offline
Not So Random!
FRC #0172 (FALGOR)
Team Role: Electrical
K.Porter will become famous soon enough
Send a message via AIM to K.Porter Send a message via MSN to K.Porter
Main Power Terminal Blocks?
I've been laying out some diagrams for the electrical on this year's robot, and the only components that I haven't been familiar with are the new terminal blocks.
These are the modular square boxes that are intended to be attached to a supplied rail.
On FIRST's supplied diagram, they are wired between the main breaker/switch and all of the breaker panels and components. I've never used terminal strips like this, I've just wired directly from the positive output on the main switch to the positive input on the component boards, and then used a separate terminal block to return on the negatives to.
So really, my question is, does anyone know if these terminal blocks have to be wired to the positive side of the circuit out of the main breaker?
Thanks.
-Kevin
Terminal Blocks in Kit of Parts? Mark Pierce Electrical 13 24-01-2007 00:37
pic: Shaft Drive Bearing Blocks MAteo9944 Extra Discussion 25 01-01-2007 11:22
[OCCRA]: Pillow Blocks? Fizzix OCCRA Q&A 1 12-10-2004 20:57
Power Terminal Block Model Ed Sparks Inventor 1 11-02-2004 06:55
pillow blocks Jacqui Sutton Kit & Additional Hardware 1 11-01-2003 10:43
