Go to Post ummm who is John V Neun....? - Korbin [more]
Unread 09-01-2007, 20:17
DPPT1717 DPPT1717 is offline
FRC #1717
DPPT1717 is an unknown quantity at this point
Magnetic Sensor on Pistons(help)
(Regarding the magnetic option for the free pistons off bimba)
What does the magnetic sensor actually do?
How does it send that information?
Is there a downside to getting it on the piston?
Is it removable if we decide to not use it?
Unread 09-01-2007, 21:21
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
Re: Magnetic Sensor on Pistons(help)
There is a magnet on the piston inside the cylinder. Two removable sensors are clamped to the outside of the cylinder. The they trigger when the piston inside the cylinder moves under them. They have outputs that can be connected to the digital inputs on the robot controller. There is no downside i can think of.
1139 Alumni
Unread 09-01-2007, 21:25
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
I've ordered these before, and I've wondered if the magnet makes the cylinder heavier. Bimba's website doesn't seem to provide any helpful info. Any empirical data?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 09-01-2007, 21:30
DonRotolo's Avatar
Back to humble
FRC #0832
If it did, it couldn't be more than a few ounces.
Don
Unread 09-01-2007, 21:32
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Not 100% sure, but I believe that all the cylinders have the magnet in them, it's just a matter of putting the sensors on the outside. It seems like you can order those sensors alone. We have a few with the sensors in our shop, I'll take a look at them.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 09-01-2007, 21:35
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Okay, I had previously thought that the only difference was that they include the sensors, but I wasn't sure if they modified the cylinder. Thanks.
_
Unread 09-01-2007, 21:37
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
Team Role: Mechanical
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
I believe that there are small magnets on the piston ring and the sensor is a switch that closes when the magnet passes under it and opens when the magnet is not near. As for weight it weight mere ounces and there is no drawback to them at all. You might have a problem with programming if running a program means meeting the condition of the switch being closed if you decide to suddenly remove it, so be careful to check your programming
-eugene
Championship - Delphi "Driving Tomorrows Technology"
Unread 09-01-2007, 21:39
Umm Errr...
It does alter the weight, but not by much. When you specify the magnet option, the piston inside the cylinder is extended by .15" to make room for the magnet ring behind the pressure seal. The cylinder wall is also extended by .15" to accomidate for this. The piston is made of aluminum and the magnetic ring is made of a pliable magnetic material similar to that which fridge magnets are constructed of.
1139 Alumni
Unread 11-01-2007, 23:49
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Another question regarding the magnetic sensors:
Are you supposed to get TWO sensors whenever you order the magnetic cylinder variant?
Last year, we only got ONE sensor per magnetic cylinder.
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Unread 12-01-2007, 11:02
Monkayyyyy's Avatar
Monkayyyyy Monkayyyyy is offline
FRC #1751 (Harbingers)
Team Role: Leadership
Monkayyyyy is on a distinguished road
Send a message via AIM to Monkayyyyy
Can u even use the actuater from last year's kit?
Work For A Better Future
2008- SBPLI Regional Delphi Driving Tomorrow's Technology Award
Unread 12-01-2007, 12:00
kmcclary's Avatar
Rookie Year: 1994
Check the 2007 rules to verify this, but in the past as long as the cylinder is legitimate for this year's contest, it doesn't matter when you bought it.
The main areas to verify though are:
1) Is it still "unmodified"? (In the past, you couldn't modify cylinders - have you done anything to it?)
2) Is it a legitimate cylinder for this year's contest? (IOW, is it still on the "coupon" in the 2007 Pneumatics Manual? Normally, the only cylinders allowed at all are ones that match the coupon's options.)
3) Does it conform to the FIRST part usage flowchart? (If it is on the coupon, then the answer should be "yes", but check anyway. In the past there has been contradictory data between the Pneumatics Manual and the build rules. I see that this year's 2007 Pneumatics Manual has "disclaimers" on each page, stating that "the contest rules take precidence" over it..)
4) Does using it still keep you within your "max number of cylinders allowed" limit? (You're normally given three FREE ones by the coupon, but the TOTAL number of cylinders allowed vary from year to year. See the rules for the decision on this year's game. I believe we're NOT limited in total cylinders this year...)
If you can answer "Yes" to all four questions, then you should be OK.
I hope this helps!
- Keith
Sensor Help itzrobz Programming 1 05-02-2006 14:07
Magnetic Reed Switches (need help) cdennisxlx2 Pneumatics 1 03-02-2006 06:47
Help with sonar sensor supertw Electrical 3 24-01-2006 23:41
magnetic sensor Justin_302 Electrical 5 22-02-2005 13:32
Banner Sensor Help ten3brousone Programming 1 13-02-2005 11:05
