Why should I update my 2006 code?
It seems like all of the things Kevin kindly updated, I already did myself last season:
" Altered tracking algorithm to use the t-packet confidence value to determine whether the code should track or search. Added Get_Tracking_State() function, which can be used to determine if the camera is pointing at the target." " Provided two new functions to set the pan and tilt servo position. This was done to provide a level of indirection so that the servos could be controlled from the robot controller or the CMUcam2." I saw that t-packet confidence could be useful, and added it to the if() in tracking.c before it romped off tracking the "target". I also don't need a Get_Tracking_State() as I just check to see if tpackets.my = 1 before I let it go go romping off tracking. And yeah, I noticed that some of the PWM values were fuzzy as well while testing. But, I just changed tracking.h around and got it to work fine. " Fixed bug in search initialization code where temp_pan_servo was initialized to zero instead of Tracking_Config_Data.Pan_Min_PWM." Hmmm, didn't really have any problems with this. Am I missing something huge here? Is there really any need to update? |
Re: Why should I update my 2006 code?
Yes - you are not allowed to reuse the code you wrote last year:
I think that that rule is just there to stop teams from "generic" coding their bot off-season. Just as building a bot off season is not allowed, I agree, the same should apply to the code behind the bot. However, since 95% of my code was not specific to "Aim-High", it can be reused via cut and paste. Am I correct in saying this?
As Dave points out, this is rule <R76>, which is on page 24 of section 8. This rule was definitely in effect last year, too. It came part and parcel with the whole Fix-it Window revolution. As far as lawyering it, the rule is pretty clear in saying that while the design can be reused, the actual lines of code cannot.
It says designs AND algorithms may be reused. So as long as I take out the code for the shooter, I am not violating the rule.
| Why Ref’s should always throw flags | BLCamp | Championship Event | 8 | 11-05-2006 08:19 |
| Master code update | Eldarion | Control System | 1 | 09-03-2006 21:14 |
| Why should Andy be on Survivor? | George1902 | General Forum | 24 | 21-06-2004 01:19 |
| What Features Should the Default Code REALLY include? | Joe Johnson | Programming | 30 | 29-04-2004 22:39 |
| Why I think FIRST should reconsider... | Joe Johnson | General Forum | 36 | 14-01-2003 15:51 |
