Go to Post School cannot teach everything you need to know so they teach you how to learn. - kstl99 [more]
View Poll Results: Pick which in your opinion is better: Scissors Lift or DoubleJointed Arm
Scissors Lift 26 29.89%
Double Jointed Arm 61 70.11%
Voters: 87. You may not vote on this poll
Unread 09-01-2007, 22:16
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
ScissorsLift vs. DoubleJointed Arm.
What would you say the Pros and Cons are for both. Also, please vote in the poll. And can you post picture, or links to pictures of past double jointed arms or scissor lifts. Thank you.
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 09-01-2007, 22:18
DonRotolo's Avatar
Back to humble
FRC #0832
Re: ScissorsLift vs. DoubleJointed Arm.
Poll?
Scissors Lift suffers fron robustness problems, kinda floppy and each joint is critical. DJ Arm is often heavier and technically more challenging, but stable, strong and potentially more robust
Don
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
Team Role: Mechanical
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Both can be used for their own purposes. However i like the scissor lift better because if you build it to support all 4 corners it will be a lot more stable and safer. the most important part is to have cross bars and the joints must be made very well
Championship - Delphi "Driving Tomorrows Technology"
Unread 09-01-2007, 22:21
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
Scissor lifts are (typically) more difficult to manufacture, more complex, heavier, and often slower. Additionally, they cannot articulate as accurately, or create any horizontal displacement or manipulation.
Being correct doesn't mean you don't have to explain yourself.
Unread 09-01-2007, 22:25
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
It's a lot harder to build a good scissors lift than an arm. I assume the OP was talking about a device to lift tubes, right? I wouldn't use a scissors lift unless I was picking up something heavy. You could build a pretty light arm for the tubes, although it's tempting to build a heavier one that could right the robot if it tips.
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
Unread 09-01-2007, 22:22
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
From an engineering standpoint (even though I'm not an engineer by any means) a scissor lift is not meant to work without springs and/or pneumatics. To build a scissor lift that is robust enough to not sway would take considerable weight, and you may not have enough weight left over for a full pneumatics system. Also, I believe springs are still outlawed in the rules.
I guess this makes a double jointed arm your best choice.
Unread 09-01-2007, 23:27
Guru's Avatar
Guru Guru is offline
Executive Programmer
FRC #0912 (Iron Lyons)
Guru is an unknown quantity at this point
I believe energy storage through springs is perfectly legal, although i cant find the rule right at this moment.
Unread 10-01-2007, 00:06
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
For the application of lifting a robot (or two) 12 inches, none of the sway problems stated above would really apply to the situation, and since you would only need a single joint, neither are the "every joint being critical" arguments. The single joint would allow you to Brace the lift in multiple places.(Shown by red circles in the below picture)
Now, in addition to keeping the scissor lift from swaying, the braces would also keep it from closing all the way, as is pictured below... but that is still adequate for the amount of space we have available to us.
A scissor lift could be a wonderful Idea for this years competition, It just depends which application you are using it for
For a scoring arm, however this would be an entirely different story...
Unread 10-01-2007, 10:32
DonRotolo's Avatar
Back to humble
FRC #0832
I think the choice of arm or lift was meant for a scoring system, not a robot lift, but I admit it's completely ambiguous given this year's game... Ain't it fun?
Don
Unread 10-01-2007, 13:52
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
Either approach can be made to work but there are a few things you need to understand.
Scissor Lift
These require tight joints that only move the way intended. Sideways slop in your pivot joints will make the structure completely unmanageable. The members of the lift must also be pretty stiff, they cannot deflect much under load. Again deflections can make the lift unmanageable.
Another thing to consider is that the lower the scissors lift gets, the more force is required to raise it. The force required can be several times the weight of the lift and the object you are lifting combined. That is why springs connecting the joints help so much, they apply force in the direction needed.
However you only have one thing to control and it should be fairly easy to get precise positioning if you use a ball screw or something similar to activate the lift. This can be a real advantage if you are trying to acheive a precise height.
Double Jointed Arm
The double jointed arm has many fewer parts. This will make it structurally much easier to build than a scissors. But it will be much more difficult to position precisely. This is because a small variation in the angle of the arm at the pivot will result in a large displacement at the end of the arm. Now add the uncertainty of the second joint to that. You will get a fairly large uncertainty in your vertical position. You will also have a similar uncertainty in your horizontal position
You might have trouble resolving the joint angle sufficiently acurately to achieve precise position control. Then you will have to rely on your arm driver to compensate.
The higest stress on the arm will be when it is fully extended horizontally. Be sure that the arm will move upwards from this position while carrying a payload. Your operator may know that he or she should not exceed a certain limit to prevent arm failure. But I can guarantee that sooner or later they will make a mistake and the dreaded full extension will occur.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 10-01-2007, 01:20
KarenH's Avatar
KarenH KarenH is offline
Mrs. ChrisH
Team Role: Parent
KarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond repute
Robot Rules, 8.3.1 General Design & Safety Rules
Under <R02> (about energy used on the robots--one of 4 permitted energy sources):
"Storage achieved by deformation of ROBOT parts. Teams must be very careful when incorporating springs or other items to store energy on their ROBOT by means of part or material deformation. A ROBOT may be rejected at inspection if, in the judgment of the inspector, such items are unsafe."
In summary, SAFE springs are legal. The definition of a spring seems pretty broad. I believe a spring is safe if it is:
1) Not likely to break
2) Well secured at both ends
3) A suitable strength for the application.
Humorous illustration: There was a fiction piece in the December 2006 Boys Life magazine about a boy who designed a revolving Christmas tree using a wind-up mechanism powered by an inner tube. He did not have adequate restraints on his device, as he learned when he released the catch...
Karen Husmann
Ex Robo-widow
Unread 10-01-2007, 04:28
Heretic121 Heretic121 is offline
The Resident Gamer -
AKA: Pat or Harry... if you ask its a long story...
FRC #0078 (AIR Strike)
Team Role: Tactician
Heretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond repute
Send a message via AIM to Heretic121
no talk of elavators!?! =O
2004 - Team 121 Human Player
2005 - Team 121 Student Captian
2006 - Team 38 Drive Team Coach / Mentor
2007 - 2009 - Team 121 Mentor / Strategery Master
2010 - 2013 - Team 78 Mentor / Strategy / Scouting Lead
2014 - Team 78 coach
Unread 09-01-2007, 22:37
DB_UPS's Avatar
DB_UPS DB_UPS is offline
tool or die that is the question?
AKA: Ryan Quinlan
FRC #1675 (The Ultimate Prtoection Squad)
DB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura about
Send a message via AIM to DB_UPS
Thank you, thats is the same points i brought up.
Unread 09-01-2007, 22:58
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
Uh, neither? Our team has had bad experiences with both; a scissor lift in 2002 had trouble supporting any kind of weight at all (similarly, team 898 from next door to us tried it in 2004 and had to toss it when it couldn't support weight), and a double jointed arm in 2003 could not even support its own weight and destroyed itself (part of this was due to a miscalculation in the strain on sprockets, but regardless it still wouldn't have gone well).
We're convinced the way to go is a combination elevator/arm like we used in 2005; we've already decided we'll be doing it for this year's bot, it's just a question of exactly how they are given power to move that is up now.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
  #15   Spotlight this post!
Unread 09-01-2007, 23:15
Joe_Widen's Avatar
My team and I were having a debate, and for some reason there was a red flag shooting up in my mind whenever I hear scissor lift. I'm just trying to figure out what the red flag is....?
80/20 arm Lil_moe Technical Discussion 2 05-02-2005 09:05
arm design Zippiot Technical Discussion 32 27-01-2005 02:56
telescoping arm CharlieWilken Technical Discussion 45 26-01-2004 22:22
pic: Arm vs Arm CD47-Bot Extra Discussion 2 13-03-2003 12:37
MY ARM!!! Jeff Rodriguez Chit-Chat 6 18-05-2002 20:24
