Go to Post adulthood is overrated. people just give you wierd looks when you play with your transformers, nerf guns and lightsabres. - Tytus Gerrish [more]
Unread 18-01-2007, 07:50
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Crab drive without a pot
Originally Posted by Don Rotolo View Post
Don't be afraid of potentiometers. Do use the correct value (I think 2.5k is the best match for the RC - or is it 5k??). Linear taper, as eshteyn noted, is what you need.
Don
100k wired as shown in the RC manual.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 18-01-2007, 09:15
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
100K is for the OI. The RC manual shows 10K in use, but says anything between 250 ohm and 100K can be used.
Unread 18-01-2007, 09:17
Unsung FIRST Hero
Rookie Year: 1996
From the 2007 RC Reference Guide...
9. Analog Inputs
The analog inputs on the Robot Controller can be used to measure various conditions on the robot and
trigger automatic responses by the control program. There are 16 analog inputs available on the
ANALOG INPUTS connectors on the Full-Size Robot Controller.
Any sensor which outputs a variable 0-5V signal may be read with 10-bit resolution on these inputs.
Popular devices include potentiometers and gyro (yaw rate) sensors. Potentiometers should be wired per
the diagram below when connecting to the Analog Inputs. Always use 100kΩ potentiometers. For
wiring yaw rate sensors, refer to the sensor manufacturer’s data sheet.
Al
WB9UVJ
www.wildstang.org
Unread 18-01-2007, 09:21
Software Engineer
Rookie Year: 1995
9. Analog Inputs
The 2007 RC Reference Guide (dated 6-13-2006, and I just downloaded it from IFI) I have open says:
Originally Posted by 2007 RC Reference Guide
9. Analog Inputs
The analog inputs on the Robot Controller can be used to measure various conditions on the robot and trigger automatic responses by the control program. There are 16 analog inputs available on the ANALOG INPUTS connectors on the Full-Size Robot Controller. Any sensor which outputs a variable 0-5V signal may be read with 10-bit resolution on these inputs.
Popular devices include potentiometers and gyro (yaw rate) sensors. Potentiometers should be wired per the diagram below when connecting to the Analog Inputs. Use 250Ω – 100KΩ potentiometers. For wiring yaw rate sensors, refer to the sensor manufacturer’s data sheet.
And the diagram below it shows a 10K pot being used.
Are you looking at an old version?
Unread 18-01-2007, 09:25
Unsung FIRST Hero
Rookie Year: 1996
Yes you're right, the version I had downloaded earlier this month was dated in February sometime and that was what I quoted. I just downloaded the newest version and it contains the above quote. Old is deleted.
Al
WB9UVJ
www.wildstang.org
Unread 19-01-2007, 20:05
B.Johnston B.Johnston is offline
AKA: Bruce Johnston
B.Johnston will become famous soon enough
I'm not sure if everyones missed the link that tristan posted, but, there's everything to "fear" about pots.
Even the best Linear pots exhibit some degree of non linearity especially near the outer portions of their range.
They suffer from thermal drift to some degree.
Mechanical forces on the shaft (not true to the rotational axis) affect the value at the wiper.
Shocks to the housing can shift values even when the pot isn't being rotated.
And last but not least exceeding the stop at the end of travel usually causes bad things to happen.
Why not revisit Tristans post and have another look at an "active" system with the potential to eliminate most of these problems.
I know that to a team, every Niagara First Team 1680, 1503 and 1114 would caution that if you can find a device for as close to the price of a precision pot without the drawbacks. Try it. 1503 and 1680 won't be going back to pots again if they can help it.
Unread 20-01-2007, 00:51
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
We have used pots successfully for many years. Ofcourse we have to recalibrate them from time to time, but as long as you make sure you dont break(mechanically, and wire them correctly, and use the correct potentiometer) them, they work wonderfully(atleast for us).
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
Crab Drive Joe_Widen Technical Discussion 9 21-04-2006 21:50
Crab drive question Tazlikesrobots Technical Discussion 13 31-07-2005 20:51
EduRobot Crab Drive OneAngryDaisy Robotics Education and Curriculum 8 03-10-2003 10:06
Crab Drive Collin Fultz Technical Discussion 3 04-09-2002 16:35
