Go to Post This has to be the hardest, most complicated game I've ever seen the GDC develop - that's what makes it so much fun! - SteveGPage [more]
Unread 10-01-2007, 10:40
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Rookie Year: 2007
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
MPlab giving problems?(or it's us?)
Hi, rookie team #2230. New to MPLab.
Everything was installed properlly.
We're trying to open some of Kevin's workspaces, but we get the following error:
"No message error is avaiable."
And then nothing happens.
Soo much for a no message error.
What's the problem?
Unread 11-01-2007, 09:32
darist darist is offline
AKA: David Aristizabal
darist is an unknown quantity at this point
Re: MPlab giving problems?(or it's us?)
What's the problem?
Wow... hard to tell. I haven't seen that one before.
Does it happen right when you open the file, or when you try to compile/build?
Try this to open the project:
1. Unzip the cotents of the zip file in a folder near the root (like C:\first\kevin\) -- MPLAB has a limit on the number of characters in the path to your project. I've also heard people say you should not have spaces in the path
2. Open MPLAB
3. Go to Project (not File) > Open ...
4. browse to the location of the project and open the .mcp file
Did this help?
David A.
Unread 11-01-2007, 10:28
AKA: Nir Levanon
Rookie Year: 2007
Already fixed. Only problem is with the proggraming itself. I posted it it in another post.
pic: It's a bird.. It's a plane.. It's the 573 Mech Warrior bot! Lisa Perez Robot Showcase 3 27-02-2005 15:09
Problems with MPLAB Charley Programming 20 25-02-2004 18:13
If you're having MPLAB problems, LOOK HERE. Jeremy_Mc Programming 0 20-01-2004 18:06
Im Having Problems With Mplab!!!! hedgehogger Programming 2 20-01-2004 17:43
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
