Where do I find the pneumatics usage rules?
Well this year pistons where not included in the KoP . . . and there's nothing about them on the rules. Can we use them? If anyone has some info from FIRST it would be really appreciated.
THANKS |
Re: Where do I find the pneumatics usage rules?
You can order 2 free pistons of any size from first as well as a rotary actuator. Also if you need more pistons order them from www.bimba.com as long as they meet first pneumatics specs
Section 8.3.10 of the manual is the pneumatics section. You will probally find <R 106> of particular use.
Wetzel |
On a pedantic note, you can order a third piston instead of the rotary actuator. However, you cannot order more than one rotary actuator for free.
If you go to the given link and click on the FIRST logo, you go directly there. Otherwise, click on the following link: http://www.bimba.com/FirstFree.aspx
| Where to find the Rule Manual? | G1279 | Rules/Strategy | 3 | 06-01-2007 19:25 |
| where Do you Find The New code | BPGBoi | Programming | 2 | 03-02-2006 17:03 |
| where can I find the code for the first 15 seconds? | CompMaster | Programming | 2 | 16-02-2005 16:23 |
| Where can I find the new C compiler? | CompMaster | Programming | 2 | 13-01-2005 02:28 |
| Where to find the containers | AndyTeam980 | General Forum | 5 | 19-01-2003 23:49 |
