The way I see it is that AutoCAD is to Inventor as Dos is to WIndows XP
AutoCAD gives you more control while it may take you longer where as Inventor looks nicer and takes less time. I wanna here from fellow AutoCAD devotees and the Inventor Buffs about why you like your software better. who knows, mabye you convert me. all I know is i have never once come up against something i can draw in autoCAD's 3D enviroment and why learn a new program if the one i am using works fine. like the old saying goes, why fix what aint broke. |
Re: AutoCAD vs. Inventor
I love both programs but I would lean more toward Inventor. AutoCAD is great because you can design ANYTHING you want to and you have endless possibilities and the program doesnt make your computer lag as much as Inventor but in Inventor you can actually visualize the part or robot right in front of you and you can animate 3D movements demonstrating how the robot works or how its put together.
I love having the control over AutoCAD as you plot drawings, and the fact that _underscore is very easy to learn and adopt. I tried learning Inventor on 10 but the shock of not using _underscore was a little too much for me, and I've kinda given it up.
Another thing was the other day when our machinist mentor looked at one inventor image and said he didn't like the application. So...if he doesn't want to use it then I probably won't use it very much, either. On another note, CNC mills, lathes, laser cutters, and waterjet cutters all use AutoCAD because it they are tools that work mostly in two-dimensional motions on an x-y axis. Last edited by Gabe : 11-01-2007 at 01:43. |
In our lab, we use a variety of programs in conjuction with the different machines. Our CNC mill runs on GCode generated using MasterCAM V. 9, which in turn uses DXF or DWG formatted files that I can export from Solidworks. Our laser cutter acts similarly to a printer and so we use Microsoft's Visio as a CAD/CAM application. It allows us to draw basic shapes easily, but also can import DXF or DWG formatted files from other CAD packages. Finally, our plasma cutter is set up to use SheetCAM to generate GCode based on DXF or DWG files. Last edited by Madison : 11-01-2007 at 01:52. |
As to the original question, I hate AutoCAD for it's lack of parametrics, liked Inventor, and love Solidworks. Last edited by Cory : 11-01-2007 at 02:03. |
Autocad - Abosolutely love using it. This is one software that I use on daily basis. Even though inventor is more user friendly, in my opinion autocad is more user friendly (I guess it really depends on the user). Tytus was the first person who got me into Autocad and he showed me few techniques. Overtime I became faster at designing things in Autocad. Since then I have been using it.
Inventor - It's a great tool when it's time to design a robot or small parts. But most of the industrial companies use Pro E or Autocad. If I have to make a small part of something that I want to show students, I use inventor. Even Though I have heard people say that inventor is VERY user friendly and one can design something in it really FAST, I think it really depends on the user and what the user is most comfortable with. ... Have knowledge in all the cad softwares possible, it helps, but use the one that you are most comfortable with. |
My main point is that all of these machines work primarily with x and y coordinate motions, where AutoCAD works very well for me. And, as Arefin mentioned above, is the application I am most familiar with. Last edited by Gabe : 11-01-2007 at 02:07. |
I like solidworks for making killer assemblies and for general modelling, but for display, inventer is FAR ahead. Solidworks seems to lag on even the most powerful machines I can find.
I've found the opposite to be true, for me. Solidworks runs faster all around, compared to Inventor. Especially on startup.
#10
I can't speak for solidworks, as I have never used it. Then again, it's not in the thread title
![]() I cannot stress how much I prefer Inventor, especially for the applications that we are using in FIRST. I have used AutoCAD outside of first (designing test fixtures), and I felt a bit limited because my designs were 3D and lacked the flexibility that sketch constraints in Inventor have. AutoCAD was just not built for assemblies, either. With that said, AutoCAD does do a lot better than some Other CAD programs than what I've used. |
#11
AutoCAD is obsolete technology. Period!
AutoCAD users are a dime-a-dozen. Literally. Prepare yourself for the future by learning the next generation of tools. http://home.pct.edu/~jmather/content..._Tutorials.htm |
#13
I am better at modeling with Inventor however I prefer AutoCAD. I generally use autoCAD for the geometry solving and Inventor for visualizing new ideas.
#14
Like with any program people will use what they are most skilled at. and companies will use what will fit their needs. I use autocad all day at work and am congenly refered to as the "MASTER MODELER" because i can model very quivkley and know lots of tricks to get the geometry and features you want for most given projects. as such i say autocad modeling is much quicker for me than inventor. however. with inventor once the parametric parameters are steup changes beciome easer.
#15
FYI: I am known here as the "Inventor Guru". ![]() |
| Activating ADA (Inventor, AutoCAD...) | SteveC116 | Technical Discussion | 2 | 11-01-2005 16:20 |
| AutoCad Inventor in KOP? | Chris_Elston | General Forum | 7 | 08-01-2005 20:13 |
| Inventor to AutoCAD | rmmlg | Inventor | 10 | 14-12-2004 21:26 |
| AutoCAD/Inventor parts library | archiver | 2000 | 3 | 23-06-2002 22:32 |
| AutoCAD, Inventor, or Other | D.J. Fluck | General Forum | 23 | 31-12-2001 08:59 |
