Go to Post That little 18 amp-hour battery has a really hard life in a FIRST robot. - eugenebrooks [more]
Unread 11-01-2007, 03:29
ptan ptan is offline
Paul C. Tan., P.Eng.
AKA: Paul Tan
no team (Bolt Action)
Rookie Year: 2000
ptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to behold
Lights on Robot
Are lights allowed on the robots to assist in target alignment in operator mode?
I.e. can we put flashing lights on top of the robot that will light when it is in the right position to drop the ringers?
The lights would be driven by the RC.
Thanks.
Mentor and new to FRC
Unread 11-01-2007, 07:12
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
Re: Lights on Robot
Something else to consider is to put those lights on your controller instead of the robot. That way your drivers look very smooth and prepared, and I could see that flashing lights on the robot would serve as a beacon to the opposing teams to come defend you vigorously.
Hi!
Unread 11-01-2007, 07:55
Travis Hoffman's Avatar Unsung FIRST Hero
Travis Hoffman Travis Hoffman is offline
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Travis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond repute
Re: Lights on Robot
Check out the Robot Feedback LED's on the Operator Interface. You can use these to signal your drivers that the robot is aligned (and no one on the other alliance has to know!).
You can use the RC to turn the Robot Feedback LED's on the OI on or off. The variables are already defined in the default MPLAB code. The variable names correspond to the descriptive labels printed on the Operator Interface:
OI Port 1 LED Output Variables:
Pwm1_green (Code: Pwm1_green = 1; //turns on the LED. 0 to turn off.)
Pwm1_red
Pwm2_green
Pwm2_red
OI Port 3 LED Output Variables:
Relay1_green
Relay1_red
Relay2_green
Relay2_red
If you want to, you can build your own LED lights into a custom button box (example) and wire the LED's to LED output pins on OI Ports 1 and 3. These outputs will be controlled by the same custom RC code that turns the OI's Feedback LED's on and off. Check out the OI Reference Guide on ifirobotics.com for more information on how to do this:
http://www.ifirobotics.com/oi.shtml
http://www.ifirobotics.com/docs/oi-r...e-11-21-05.pdf
We always go to Radio Shack and buy the LED modules with built-in resistors for use on our team's button box. They always work out well. Red wire to desired LED output; black wire to any available Ground pin.
Travis Hoffman, Enginerd, FRC Team 48 Delphi E.L.I.T.E.
Encouraging Learning in Technology and Engineering - www.delphielite.com
NEOFRA - Northeast Ohio FIRST Robotics Alliance - www.neofra.com
NEOFRA / Delphi E.L.I.T.E. FLL Regional Partner
Unread 11-01-2007, 08:12
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Re: Lights on Robot
I agree, these LEDs can be used to great benefit. We used a system like this last year to show when the base was lined up to drop balls. The driver drove like normal, and the operator watched the LEDs for them to go all green. You can even add functionality to show where you need to drive beforehand!
Unread 11-01-2007, 13:50
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
Re: Lights on Robot
Just remember if you use this, that the data for the LEDs is the same one used for the user byte if you display the user byte in the little LED display on your OI; they can't be used simultaneously. It took us half a competition to figure that out last year.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Unread 11-01-2007, 13:56
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Re: Lights on Robot
Are LEDs legal on the robot if used with optical sensors?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 11-01-2007, 15:44
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
Rookie Year: 2000
ttedrow will become famous soon enoughttedrow will become famous soon enough
Re: Lights on Robot
LED Light are permitted on the Robot as long a there are no other rules violations. Don't use green LED. They may interfer with other robot targeting systems.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Lights? Total Meltdown Programming 2 17-01-2006 00:35
Flashing Red Robot Feedback Lights zarf Programming 2 12-02-2005 16:01
Pretty Lights... archiver 2001 1 24-06-2002 02:17
Lights on our robot (in addition to the rotating light)... archiver 2001 1 24-06-2002 01:02
is anyone wanting a lot of lights (decorative) on the robot? archiver 2001 5 24-06-2002 00:09
