Question about CMUCAM servo output
The servo output is the pan and tilt. My question is: what output does it give? I mean, is it outputed in degrees? I'm working with easyC and the output is an unsigned char, so it is only positive numbers. So is the output the number of degrees the servo turned from it's start point?
| Question about the CMUCam | Dan Petrovic | Programming | 2 | 19-09-2006 21:27 |
| Cmucam + track color + auto servo mode | kheops1982 | Programming | 5 | 09-04-2006 13:32 |
| servo output accuracy | NextPerception | Programming | 9 | 07-02-2006 11:23 |
| Servo behavior question / advanced servo/PIC programming question | DanL | Electrical | 12 | 18-10-2005 18:33 |
| Dashboard Output Question | jnossen | Technical Discussion | 5 | 02-02-2002 19:52 |
