Go to Post Through 30 years of teaching I've heard the same refrain..."I love science, I love math but I can't stand my language classes". Well enough is enough. Get over it. - Mr.B [more]
Unread 01-11-2007, 02:18 PM
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Positioning of Battery
Does the battery have to maintain a statically mounted position on the frame of the robot? For example, bolted securely to the main frame. Or can we have it securely mounted to a moving part?
I suspect this is a question for FIRST and that there isn't a rule specifying this, however, I can't find the Q&A forum this year... all i can find on usfirst.org is last year's Q&A.
Thanks,
Duane J.
Unread 01-11-2007, 02:23 PM
Drew's Avatar
Drew Drew is offline
Drew
FRC #0302 (Dragons)
Team Role: Animator
Drew is a jewel in the roughDrew is a jewel in the roughDrew is a jewel in the roughDrew is a jewel in the rough
Send a message via AIM to Drew
Re: Positioning of Battery
To answer this question to the best of my knowledge I would have to say that the battery would be mounted to an unmovable peice of your robot. Not because it says this anywhere in the rules but because if the battery holder moves then you run a chance of it falling out or wires being hit or disconnected. If the platform that it is mounted to does a complete 360 then you must make sure that the wires can handle the spinning so that you do not rip them from the plug. This is just my input on this situation. Also you may want the battery closest to the ground and opposite of your arm mechanism to maintain stablility of the robot. not a constand changing of weight.
Unread 01-11-2007, 02:29 PM
It would be mounted in such a way that travel is minimal, and there would be no risk of dropping the battery, wire entanglement, etc.
Unread 01-11-2007, 02:36 PM
Drew's Avatar
Drew
FRC #0302 (Dragons)
Team Role: Animator
From what I see go for it, there isnt anything that I have read about it.
Unread 01-11-2007, 02:39 PM
jparkteach's Avatar
jparkteach jparkteach is offline
FRC #2070 (Ridgefield Robotics)
jparkteach is a splendid one to beholdjparkteach is a splendid one to beholdjparkteach is a splendid one to beholdjparkteach is a splendid one to beholdjparkteach is a splendid one to beholdjparkteach is a splendid one to behold
Send a message via AIM to jparkteach
I wouldn't mount the battery onto anything that's not directly connected to the chassis and secure. Remember the impulse these heavy batteries would undergo and imagine the force they're under. Putting these batteries onto anything inside your robot that's movable or sliding would be a grave mistake. Just my opinion...
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Here is a link to the Q&A Forum since you couldn't find it
Unread 01-11-2007, 03:01 PM
Jonathan Jonathan is offline
AKA: "Boss" or "The Other Boss"
FRC #0316 (LuNaTeCs)
Jonathan will become famous soon enough
Send a message via AIM to Jonathan
Back in 2005 we put our battery and air compressor in a box. It was unsecured, all it did was sit in it. Then we used a cyclinder to shoot it out the back to be a counterweight system. It worked great for us. We never tipped.
Unread 01-11-2007, 05:55 PM
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
Thanks,
Duane J.
As long as it does not pose a safety hazard, I'd say you're ok to mount it on a moving part.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 01-11-2007, 07:15 PM
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
I'm pretty sure you can do whatever you want with your battery. I once wanted to use it as a counter weight for an arm, my team didn't like the idea.
Team Website
spherical positioning sciguy125 Technical Discussion 11 11-16-2005 11:22 PM
Autonomous Positioning SteveO Programming 9 01-16-2005 06:14 PM
positioning system srjjs Technical Discussion 5 04-05-2003 02:49 PM
Robot Positioning Devices austind27 General Forum 10 02-11-2003 09:58 PM
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 02-08-2003 03:25 PM
