Go to Post Now, everyone, say it with me: "It's just a TV show and FRC is just a robotics program. My life is a lot bigger than both of those things." Once you say this, I swear most of the arguments here would fade into oblivion. - itsjustjon [more]
Unread 23-01-2007, 22:41
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Re: Backup onboard charger not correct
Originally Posted by Al Skierkiewicz View Post
Paul,
If you use the IFI charging circuit, then IFI makes it mandatory to use it as it is drawn with no mods. If the RC should fail and they determine the cause relates to backup battery it may void the warranty.
<R56> The 7.2v backup battery may be charged on or off the ROBOT. When off the ROBOT, the battery is to be charged with the provided 7.2V backup battery charger. When mounted on the ROBOT, the backup battery may be charged from the 12VDC primary battery by using the custom charging circuit available from Innovation First Inc.
There is no other provision beyond these two.
Where in the rules or on Innovation First does it say that we cannot modify this circuit to work the way we need it to work? I found nothing so we took it as a chance and modified it a bit. Added a steering diode to prevent the back feed, and we are going to add a 1 AMP fuse to it as well.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 23-01-2007, 22:57
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
The general feeling around here about <R56> is that the backup battery may only be charged by the circuit from IFI, and not from a custom circuit. I could have sworn there was a Q&A that backed up this interpretation, but I'm not seeing it under section 8.3.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 23-01-2007, 23:10
RyanN's Avatar
RyanN
Maybe this will be clarified in Team Update #6 . I have 2 things that I'm not sure about, this, and the radio problem.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 24-01-2007, 07:58
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Ryan,
I could see how it might be interpreted that way but the rules simply state the IFI suppied circuit design must be used. I read that (and the inspectors last year were interpreting it) that it is and must remain unmodified.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 24-01-2007, 08:06
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
The rules say:
<R56> The 7.2v backup battery may be charged on or off the ROBOT. When off the ROBOT, the battery is to be charged with the provided 7.2V backup battery charger. When mounted on the ROBOT, the backup battery may be charged from the 12VDC primary battery by using the custom charging circuit available from Innovation First Inc. (note: IFI will provide the design for this circuit on the IFI website, however teams must obtain the parts for this circuit and assemble it themselves). The use of this circuit is strongly encouraged.
This rule does not say that it MUST be charged with the IFI circuit. This wording appears to allow an alternate, on-robot charger. We should get an official ruling from USFIRST on this.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 24-01-2007, 08:17
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
I have already submitted a Q&A to the official FIRST forums. We should have our answer in a few days.
Unread 24-01-2007, 08:18
Unsung FIRST Hero
Rookie Year: 1996
The rules say:
Jerry,
Read that rule as "if you charge it on the robot it must use the IFI charger. If you charge it off the robot then you must use the supplied charger". There is no other alternative.
Al
WB9UVJ
www.wildstang.org
Unread 24-01-2007, 08:34
None #0612
Certainly that is the safest way to read the rule, but USFIRST has in the past been very specific in their choice between the words "may" and "must". If this rule specifically, definitively, was intended to disallow an alternate on-robot charger, is should use the word "must".
A poorly designed charger could lead to overheating of the batteries, so a specific charger design should be used here.
I'll be interested in their comments on this.
Stamp is probably not releasing a new version this week. buss Scouting 1 29-03-2006 22:10
STAMP version 1.0 (NOT BETA) is out for week 1! Ethulin Scouting 5 01-03-2006 18:50
Rookies, wish you knew that earlier? Erin Rapacki General Forum 0 24-02-2005 11:49
Backup battery will not power RC steven114 Control System 13 24-01-2005 01:59
Onboard Camera? XRaVeNX General Forum 18 03-02-2003 20:28
