Go to Post Things that get said on the field should stay on the field. - Bongle [more]
View Poll Results: Why Bumpers?
For the extra weight 3 4.23%
For the extra protection 14 19.72%
Both for the protection and weight 51 71.83%
We don't use bumpers 3 4.23%
Voters: 71. You may not vote on this poll
Unread 11-01-2007, 15:47
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
EricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond repute
Robot bumpers
What is your teams reason for using the official FIRST bumpers?
Unread 11-01-2007, 15:50
BlondeNerd's Avatar
BlondeNerd BlondeNerd is offline
AKA: Kate
FRC #0619 (Charlottesville Albermarle Robotics)
BlondeNerd is a splendid one to beholdBlondeNerd is a splendid one to beholdBlondeNerd is a splendid one to beholdBlondeNerd is a splendid one to beholdBlondeNerd is a splendid one to beholdBlondeNerd is a splendid one to beholdBlondeNerd is a splendid one to beholdBlondeNerd is a splendid one to behold
Re: Robot bumpers
Protection! The bumpers keep our bot from being damaged and damaging other bots. Just think, which is worse: being wacked with a pool noodle or being wacked with a piece of aluminum?
Why, yes, girls CAN build robots!
Unread 11-01-2007, 15:51
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Team Role: Mechanical
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Re: Robot bumpers
Bumpers don't allow you to use extra weight. Only the bumpers are weighed and have to be built to FIRST specs.
We use them because....why not?
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 11-01-2007, 21:49
MattLi's Avatar
MattLi MattLi is offline
Scrawny Asian Kid
FRC #0245 (Adambots)
Team Role: Leadership
MattLi has a spectacular aura aboutMattLi has a spectacular aura about
Re: Robot bumpers
Please explain. I pulled from this that you're saying the bumpers are included in the weighing of your robot. I was almost certain that they're not included.
Per Ardua ad Astra-Through adversity to the stars.
~Royal Air Force
Unread 11-01-2007, 22:05
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Robot bumpers
They aren't. See the rules on bumpers in Section 8. Unless, of course, you use custom bumpers, in which case you must include them both in weigh and in size.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 11-01-2007, 22:09
Mechanical/Driver
Re: Robot bumpers
No, I was correcting his statement that bumpers allow you to use extra weight on your bot, as an advantage. Since the bumpers need to be built to FIRST specs, and are weighed separately, you aren't getting a 15lb weight gain on your overall bot, ruling out using bumpers as an "extra weight" advantage.
I highly recommend to newer FIRST teams to build the bumpers. Like I said before, why not? They aren't weighed or measured with your bot...all it does is give you an advantage. If you think about it, robots accused with "ramming" your bot will get a yellow flag, etc. but remember that just because they were penalized, doesn't make the hit not happen. If it happens, it happens. If that hit puts your bot out of commission, then your team winds up more screwed than the ramming team. If you have bumpers, you have a big saftey net for rammers. That way, if someone rams you really hard, they get a yellow flag and your bot doesn't even get scratched .
In 05, the year before the bumpers were implemented, I've seen some bots with broken/bent/cracked chassis, destroyed wheels, broken chains, bent shafts, blown-up gearboxes, the works. All as a result from ramming. The bumpers will definitely protect your bot from these things better than a bot without them.
Unread 11-01-2007, 22:57
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Re: Robot bumpers
I would encourage teams to look at the bumpers as a structural element. They can be more than protection and weight. Even a strong frame can take damage from a point impact. Hitting a wall is not the same as another un-bumpered robot hitting your unbumpered robot at high speed. Our 2006 robot has a nasty dent in the frame from ramp riot.
Unread 11-01-2007, 23:29
MattLi's Avatar
Scrawny Asian Kid
Re: Robot bumpers
What would this structural element be? No matter how I think of it bumpers always strike me as either weight, protection, or stability.
~Royal Air Force
Unread 11-01-2007, 23:44
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Re: Robot bumpers
In regards to the first paragraph, I do not understand what you are saying. Bumpers are allowed to weigh up to 15 pounds, with an average of no more than 3 ounces per inch. The 15 pounds is on top of whatever weight class you choose. If my robot weighs 120 pounds, and I use bumpers, I now have a 135 pound robot. They are a weight advantage. If you don't use bumpers, you don't get that weight. <R37> clearly explains this.
Also, bumpers WERE implemented since at least 2004, but the rules were much looser and there was less of an advantage to be gained by their use.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 12-01-2007, 02:00
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Re: Robot bumpers
Often times, when people discuss the 'weight bonus' that comes with using bumpers, what they're talking about is the benefit that an additional 15 lbs. has when calculating the force of friction between the playing field and your robot's traction surfaces.
Force of friction is calculated as some coefficient of friction (mu) times a normal force. In this case, that normal force is the weight of the robot, so a higher weight provides for a higher force of friction.
More friction makes it more difficult for others to push your robot when it's standing still. The added weight doesn't allow for any benefit to mechanism design or robot function, however.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 12-01-2007, 02:18
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: Robot bumpers
Custom bumpers have been allowed for years and years, subject to the weight limit of 130 or 120 or whatever the limit was and size rules similar the the "standard" bumper. After 2005, the wedge was outlawed and the standard bumper introduced, and now we have bumpered robots everywhere.
On structural element: yes, is it possible. Run your drive similar to, say, 968 in '05 and '06, then use the bumper as an outer frame rail without the weight of one (just don't leave it on for inspection, and your robot better run without the bumper.)
Past teams:
Unread 11-01-2007, 15:52
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: Robot bumpers
We will probably be using the bumpers because it is safer. It makes our robot able to take bigger hits and lets us worry a little bit less than if it was metal to metal. From last year's robot I am thankful that we had at least corner bumpers because otherwise there were some blows that would have hurt us much more than a dent.
Also when you are talking about protection that also means weight because a low CG is protection if you really think about it.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 11-01-2007, 16:09
Charger_07 Charger_07 is offline
AKA: Escue
FRC #0932 (Circuit Chargers)
Charger_07 has a spectacular aura aboutCharger_07 has a spectacular aura about
Re: Robot bumpers
bumpers saved our robot last year since the judges decided to ignore other teams ramming
Chuck Norris likes to knit sweaters in his free time. And by "knit", I mean "kick", and by "sweaters", I mean "babies."
Nick: "I'm not Nick"
Unread 11-01-2007, 16:44
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: Robot bumpers
We use them for the weight and protection.
Plus there's the wider footprint so robots are more stable.
Originally Posted by Koko Ed View Post
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
  #15   Spotlight this post!
Unread 11-01-2007, 21:12
PDF32100 PDF32100 is offline
AKA: Pedro
FRC #0714 (SUPER PANTHERS)
Team Role: Driver
Rookie Year: 2000
PDF32100 has a spectacular aura aboutPDF32100 has a spectacular aura aboutPDF32100 has a spectacular aura about
Send a message via AIM to PDF32100 Send a message via MSN to PDF32100
Re: Robot bumpers
WELLLLLLL with our new frame we put it at full speed with 4 motors(just to try out) and rammed it to the wall a few scrathces but no damage at all but we might still use bumpers ... ITS SMART IF IT DOESN"T AFFECT U IT ONLY HELPS U DEN USE IT
Bumpers great_one411 General Forum 1 05-02-2003 16:49
RE: bumpers archiver 2000 0 24-06-2002 00:13
Bumpers archiver 2000 2 23-06-2002 22:48
Bumpers? archiver 2000 3 23-06-2002 22:32
bumpers Martin Rules/Strategy 2 13-01-2002 21:51
