Go to Post You know, I love the fact that FIRST has always got your back. :D - Beth Sweet [more]
Unread 11-01-2007, 17:15
Transformers Transformers is offline
FRC #2260 (Transformers)
Transformers is an unknown quantity at this point
Pneumatics Help
Thank you for all the help with my last thread about tracks.
I am now having problems finding a hydraulic the size that I need. I will probably need one with a 30 inch rod at least. Help finding a sight or source would be greatly appreciated. Thanks in advance.
Unread 11-01-2007, 18:12
burkey_turkey burkey_turkey is offline
AKA: Andrew
FRC #0422 (MechTechs)
Team Role: Mechanical
burkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to behold
Re: Pneumatics Help
Originally Posted by Transformers View Post
a 30m inch rod at least.
30 meter rod? or do you mean centimeter or milimeter?
Unread 11-01-2007, 18:19
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
Re: Pneumatics Help
I am now having problems finding a hydraulic the size that I need. I will probably need one with a 30m inch rod at least. Help finding a sight or source would be greatly appreciated. Thanks in advance.
Take a second...Calm down...Breath....ok much better.
First off there is a termonology problem here. Hydraulics (using oil) are not legal, while pneumatics (using compressed air) are legal. While the components look the same they are different. Next length of the stroke (the amount you want to move) has nothing to do with the force required to do so. So just figure out the length and you can order the one you need. Bimba gives each team 3 free cylinders and normally one in the kit, they still haven't shipped the pneumatics kit this year so wait a bit and soon you will know what is availalbe.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 11-01-2007, 18:22
Re: Pneumatics Help
no I mean length. I need the hydraulic rod to be 30 inches long and I can't find one anywhere.
Unread 11-01-2007, 18:29
Re: Pneumatics Help
Right, thats what I mean. I just need a pneumatic that can extend to 60 inches. I forgot that the kit wasnt shipped yet. Thanks for clearing that up.
Unread 11-01-2007, 18:33
Billfred's Avatar
Billfred Billfred is online now
Re: Pneumatics Help
Regardless of which measurement is correct, you're out of luck--Bimba's free (and thus legal) cylinders only go up to 24". And even then, you're going to use a lot of air in one use of that cylinder. Have you examined other options for your application?
Unread 11-01-2007, 18:35
Re: Pneumatics Help
oh really? well i suppose there is ways to combine pneumatics and use other motors for extensions...but thank you I was unaware of that rule.
Unread 11-01-2007, 19:47
AKA: Andrew
Re: Pneumatics Help
using very simple levers you can get more out of a piston, just less force. our team is using a small piston for our claw type mechanism, and we found that a few points of rotation can work wonders
Unread 11-01-2007, 19:56
lopz056's Avatar
lopz056 lopz056 is offline
Chris Lopez
AKA: chris lopez
FRC #1388 (Eagle Robotics)
Team Role: Leadership
Rookie Year: 2007
lopz056 is an unknown quantity at this point
Re: Pneumatics Help
well first of all i think that you should use a pnuematic system but im not entirely sure of what exactly your using it for
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Pneumatics help! Bomberofdoom Kit & Additional Hardware 2 08-01-2007 11:32
Pneumatics Help! archiver 2001 2 24-06-2002 00:45
PNEUMATICS PLEASE HELP archiver 2000 1 23-06-2002 23:06
pneumatics CD archiver 2000 2 23-06-2002 22:46
