Go to Post Teams are overconfident every year. Honest evaluation of your capabilities with regard to your design strategy is a skill few teams have. - Chris is me [more]
Unread 11-01-2007, 18:25
Daru Daru is offline
Daru has a spectacular aura aboutDaru has a spectacular aura about
BaneBot Transmission Encoder
Has anyone had a chance to play with the BaneBot Transmission Encoder?
If I am correct, they seem like they would be a good alternative to the gear tooth sensor? With the Encoder Divider they would give a signal similar to the gear tooth sensor, correct?
Our team has never used such a thing before (at least in the years I've been here...) and we're in a situation where using one would be... well, convinient.
Could anyone offer help in this matter?
Thank you,
Dave
706
Encoder Code Kevin Watson Programming 47 18-02-2008 12:56
opening up the BaneBot gearbox to install the CIM motor jskene Motors 9 22-01-2007 11:12
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? VEN Technical Discussion 4 11-01-2007 14:45
encoder.c Gary Bonner Programming 2 14-01-2005 13:41
