sprockets
If i use the andymark kit wheels and try to make a six wheel drive, is there a way to mount two sprockets on the center tire? Can i simply buy the appropriate long bolts from home depot and some small washers or do i need to use hardware titled for the wheels?
Re: sprockets
I dont see why you cant just use long bolts, thats what we would do.
Re: sprockets
We are doing the same thing with a 4WD chassis. Just get a longer bolt and run it through the wheel, and through both sprockets. Then bolt it down.
Re: sprockets
cool
thanks |
Re: sprockets
what kind of bolts might those be? i know it says somewhere but i am going dumb now that its 11pm
Re: sprockets
I believe they are .165" holes. Standard 10-32 bolts/nuts from lowes will fit.
Re: sprockets
8-32 not 10-32. took us an hour at home depot to find 2" 8-32(its a bad home depot)
Re: sprockets
Re: sprockets
10-32 if you were going to tap them, 8-32 if you want to use them as through-holes.
#10
Re: sprockets
thanks again everyone
#11
Re: sprockets
- Bochek |
#12
Re: sprockets
last year we used long bolts and simple home made spacers and it worked great. Just be sure to use loctite or they will work loose.
#13
Re: sprockets
This is possible and we have done this in the past. If you are going to do this you have to consider several items.
Any slop in the Bolts and holes will give you a potential failure point from the sheer forces. This will be exacerbated by the slop in the housing. Things to consider Oversize the holes on the wheels to .1875-.189. Add Spacers (Aluminum will work) to the sprockets try not to use a hub on the sprocket for weight. C’Bore the sprockets for the spacers Use Socket Head Cap (Ask a local machine shop or Hardware store, not Home Depot, Allen or Holo Krome) screws, as they are harder and will provide the strength. Use ny-loc nuts for later removal Do a PM (Preventive Maintenance) between matches and have spare screws Good Luck from Team #75 Team #75 Mentor |
| sprockets | carbuff | Kit & Additional Hardware | 8 | 12-01-2007 08:30 |
| Sprockets | laney836 | Chit-Chat | 3 | 02-11-2005 19:46 |
| Sprockets | VinceT | Kit & Additional Hardware | 4 | 18-01-2004 23:07 |
| sprockets | BBFIRSTCHICK | Technical Discussion | 21 | 09-02-2003 01:01 |
| sprockets | Greg Needel | Technical Discussion | 0 | 23-04-2002 12:30 |
