Go to Post Mentor: You must first learn patience... Student (impatiently): How long is that going to take? - kaszeta [more]
View Poll Results: What is your ending robot orientation
Long (38l x 28w) 86 83.50%
Wide (28l x 38w) 17 16.50%
Voters: 103. You may not vote on this poll
Unread 12-01-2007, 00:59
razor95kds's Avatar
razor95kds razor95kds is offline
razor95kds has a spectacular aura aboutrazor95kds has a spectacular aura aboutrazor95kds has a spectacular aura about
Robot orientation: Long or wide?
Our team is designing ramps for robots to climb at the end of the match but We would like to get a sense of whether the teams are going to be using the long starting orientation (38lx 28w) or the wide staring orientation (28lx 38w) so we accomodate our designs for the wide robots if necessary.
Unread 12-01-2007, 09:31
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Robot orientation: Long or wide?
My guess is that you will have a very very difficult time designing effective ramps to support "wide" robots, and only a very difficult time with ramps for "long" robots.
We're not even considering a "wide" robot ramp design.
Unread 12-01-2007, 09:34
Kim Masi's Avatar
Kim Masi Kim Masi is offline
125 Member, cause Brando says so :p
FRC #0125 (NUTRONS)
Kim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond repute
Send a message via AIM to Kim Masi
Last year, there were only a couple of robots that I could think of that went with the wide configuration. I think with this years game though, we will be seeing a lot more variety in the configuration.
This is a good poll, I was wondering the same thing.
Bobcat Robotics-Team 177: 2004-2007
The NUTRONS-Team 125: 2008-2009, 2011-2012ish
Unread 12-01-2007, 09:37
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
IMHO: There are so many more cool things you can do this year with a wide robot. Designing your point scoring systems around a "long" robot may lead to overly complex mechanisms and wasted weight.
Unread 12-01-2007, 09:45
Corey Balint Corey Balint is offline
Now comes without cockiness.
AKA: Corn Dog
FRC #0125
Corey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond repute
Send a message via AIM to Corey Balint
The design I made myself is a Wide Orientation robot, and I think, by far, it is better than any other design I've heard of yet, due to the extensive increase in capabilities compared to the vertical bot.
On that note, anyone want a pretty cool wide oriented robot design? :-p
Don't be scared to post something that is more than "dave is great" "here's my caption contest entry" and "overdrive is the best thing ever". Say something interesting. Say something that will make others think. Create discussion.
If you do say something that isn't just for fun or praising something, which hopefully you do, just be prepared to back up what you said.
Remember: GP is Gracious Professionalism, not Glorifiying Plesantries. Saying something negative does not mean you are evil. It could help someone out a lot.
Anything that I post is an opinion from my own mind. Some may agree with it, others may not. However do not negatively associate anyone else, including any team I work with, with my opinion.
Unread 12-01-2007, 09:50
MrForbes's Avatar
AKA: Jim
if you consider the issue of stability, which is vital for a robot that has to reach up high, then you will find that a wide robot design might not be the best way to go. Think about how far in from the edge the wheels contact the floor, with both designs. Think about how the spacing of the contact points affects robot stability. Also think about the effect of acceleration of the robot on stability with both possible orientations.
Unread 12-01-2007, 10:08
This can be remedied easily (see: wheelie bar). What may be harder to fix is adding an extra joint to an arm in order to pick up from the floor or human loader because your robot isn't wide enough to hold a tube in it.
Unread 12-01-2007, 10:22
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
In this game, I see a wider stance as being advantageous when fully extended vertically. If pushed from the side, the longer dimension, the robot will be stabilized. If pushed from the rear, the robot should be pushed into the rack, keeping it upright. If pushed from the front, the robot shouldn't be in that configuration anyway and deserves to be knocked over due to poor design/poor handling. As has already been said, wheelie bars are a good thing too.
Hi!
Unread 12-01-2007, 10:31
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
There's the fact that a wider robot is going to have more difficulties getting up a ramp anyways due to CG issues. If you're designing a ramp for wide bots, you should keep in mind that you'll want to shoot for a less aggressive angle to offset this. Another thing to consider is that being able to ramp any robot out there is a pretty impressive ability to throw out in a strategy meeting.
Unread 12-01-2007, 10:32
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
It might be a smart thing to design a lift that can accomodate any robot design, as this poll proves that *40% of the robots which you'll be dealing with will be "wide" configuration. Chances are, there will be a "wide" robot on the winning alliance at any given competition, and if your mechanism doesn't accomodate them, they won't pick you.
* 40% at the time of posting
Unread 12-01-2007, 10:36
MrForbes's Avatar
AKA: Jim
good idea!
thanks
Unread 12-01-2007, 23:21
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Question Re: Robot orientation: Long or wide?
What are some specifics as to why the wide platform is so much more advantageous this year?
What can uniquely be done with it that a long orientation won't allow?
Thanks in advance,
Robinson
Unread 12-01-2007, 23:36
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
We made a wide robot and had some bad luck with tipping and stuff, so we decided to stay away from that for this year.
Especially since we are going to be reaching 8 ft in the air.
Originally Posted by Koko Ed View Post
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 12-01-2007, 23:40
MattLi's Avatar
MattLi MattLi is offline
Scrawny Asian Kid
FRC #0245 (Adambots)
Team Role: Leadership
MattLi has a spectacular aura aboutMattLi has a spectacular aura about
There is another situation which could occur. The robot could not not be the max height and/or width. It could be a square robot.
In anycase a reason to pick a wide robot as opposed to a long robot would be that it's easy to turn. It also takes up more area around the rack so you could block easier.
Reason's for picking a long robot are, it's easier to build a stable long robot than a stable wide robot. You could get into the spaces between bots defending the rack easier, and it can very easily accomidate an arm.
Per Ardua ad Astra-Through adversity to the stars.
~Royal Air Force
  #15   Spotlight this post!
Unread 12-01-2007, 23:45
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
We were discussing this today, and found that with our current design*, we could accomodate one long robot and one wide robot, or two long robots.
*still being prototyped, but it looks promising, the main issue that I can see being weight.
battery orientation Brawler006 Electrical 8 26-01-2004 08:57
box orientation Lance General Forum 1 13-02-2003 10:12
Orientation Switch CyberWolf_22 Programming 6 04-02-2003 10:42
Compressor Orientation Suneet Technical Discussion 5 25-01-2002 17:33
