Go to Post I can't wait to be one of those old kids who can say "Yeah, I remember the days before districts." and then watch the kid's eyes widen when I explain the days of regionals.. - rachelholladay [more]
Unread 12-01-2007, 10:56
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
pic: 931 Preliminary Electrical Layout
Unread 12-01-2007, 11:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pic: 931 Preliminary Electrical Layout
Nice, thanks for letting us see what it looks like. Lotsa stuff on there!
The negative terminal post in the top right corner of the picture is not show on the 2007 Robot Power Distribution Diagram, and does not appear to be from the KOP. It also seems to defeat the purpose of the black Power Distribution Block (whatever that purpose might be). Are you sure it's allowed by the rules?
Unread 12-01-2007, 12:18
Rookie Year: 1996
Well spotted.
The 3/8" stud you see was a KoP item in previous years, and would be considered a COTS COMPONENT now. As such we will need to account for its cost in our materials list, and make sure that it complies with <R63> since, as an electrical conductor, it might be considered a custom circuit.
EDIT: of course under <R47> the stud is an additional electrical component, and as such would not be allowed if it is not COTS.
EDIT: Post Count = Team Number.
Richard Wallace
since 2003
Unread 12-01-2007, 12:50
MrForbes's Avatar
AKA: Jim
<R57> does not seem to specifically address the negative power distribution, but from the specifics of the positive power distribution description, I would feel much safer about passing inspection by using only the new power distribution blocks and fuse panels for all intermediate connections.
Unread 12-01-2007, 17:32
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Rookie Year: 1999
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
I honestly think that you could simplify your wiring and lose some weight if you moved the din rail closer to the radio and got rid of the stud and crimps. Thus causing one less location for something to come loose. Or better yet use the Negative posts on the smaller breaker panel. Or, I'm not sure if its required to use the din rail but you could totally eliminate the din rail and run the negative to the stud and the positives through the maxi-block.
Just a thought. I dont plan to use additional items.
-Mike
Unread 12-01-2007, 17:42
Rookie Year: 1996
-Mike
Thanks for the weight saving idea. We do plan to compress the layout after some other chassis decisions are finalized, and we may lose the stud at that point.
However, I am pretty sure the DIN Block is required per <R57>.
EDIT: also I am pretty sure that wiring 40A circuit returns to the smaller breaker panel is not allowed.
Richard Wallace
since 2003
Unread 12-01-2007, 19:57
clydefrog88's Avatar
clydefrog88 clydefrog88 is offline
FRC #4087 (Falcon Robotics)
clydefrog88 is a jewel in the roughclydefrog88 is a jewel in the roughclydefrog88 is a jewel in the roughclydefrog88 is a jewel in the rough
are you using the plywood for your final board? we've saved a lot of weight in the past few years by using 1 or 2ply of hand laid fiberglass on both sides of a balsa core. it weighs almost nothing and is strong enough for a electronics board.
Unread 12-01-2007, 20:20
Rookie Year: 1996
That sounds cool.
We have not used plywood for the electrical system board in previous years and probably won't this year either. Usually we have laser-cut 0.22" thick acrylic sheet. Wood is nice and forgiving though, and will let us experiment with layout ideas until we feel comfortable.
A factor to consider is that the kitbot frame needs some stiffening anyway, so our choice for final electrical board material may be based partly on overall robot strength requirements, not just being "strong enough for an electrical system". Sometimes adding weight to one subsystem lets you take even more weight out of another.
Richard Wallace
since 2003
Unread 13-01-2007, 15:25
xghost xghost is offline
FRC #0340
xghost is an unknown quantity at this point
Question Re: pic: 931 Preliminary Electrical Layout
The connectors on those speed controllers(red/black)...They seem very nice...look like mini battery connectors and easier than two quick disconnects terminals. Where did you get those?
Unread 13-01-2007, 18:31
Rookie Year: 1996
Those are Anderson Power Pole connectors in the 15/45 Ampere size as shown here. You can get them through several distributors. A low cost crimping tool for their terminals is available at West Mountain Radio.
Good luck this season.
Richard Wallace
since 2003
Unread 30-01-2007, 04:39
Darkswordsmith Darkswordsmith is offline
Allen's Shiznit
FRC #1678 (En-Gen)
Team Role: Electrical
Darkswordsmith is on a distinguished road
Send a message via AIM to Darkswordsmith
I'm still not sure whether we can use the negative stud in power distribution. Can anyone give a definite answer?
IRI Schedule - PRELIMINARY Chris Fultz Off-Season Events 4 05-07-2006 21:05
pic: Team 931 Summation RebelWithARobot Extra Discussion 8 10-05-2006 11:10
Team 810: Electrical Layout, rev 1 ForgottenSalad Robot Showcase 4 04-02-2006 00:03
Team 931 Omniwheels bheller Robot Showcase 7 19-02-2004 23:56
Electrical wiring layout sheet George T Electrical 1 11-02-2003 18:20
