Go to Post If you don't have a hairtie, use a ziptie instead. It works, it's cute, and way geeky. :p - Katie Reynolds [more]
Unread 12-01-2007, 11:03
ThomasP's Avatar
ThomasP ThomasP is offline
FRC #1255 (Blarglefish)
ThomasP is just really niceThomasP is just really niceThomasP is just really niceThomasP is just really nice
Send a message via AIM to ThomasP
Square PBC Tubing
Has anyone ever used square pvc tubing for their robot frame or parts on their robot? My dad suggested it and it sounded like a really good idea but before I start to attempt to convince my team I wanted to see if anyone had experience with using it before. Here's a link to it at McMaster-Carr, I was thinking about suggesting the 3/4" square with .137" wall thickness.
http://www.mcmaster.com/nav/enter.asp?pagenum=3359
Unread 12-01-2007, 11:08
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
Re: Square PBC Tubing
PVC is often really easy to work with as it is quick to cut, and with fittings it is easy to make structure. I think PVC has a high likelihood to crack though, and the weight savings over aluminum might not make it worth it, especially in the square tube. (I have not used it before, but if you do end up using it it would be cool if you could post your overall experience with it!)
It looks like the wall thickness is about that of 1" schedule 40 round tube:
http://www.engineeringtoolbox.com/pv...ons-d_795.html
I have made some things in the past from this 1" tube and when it takes some hits it has cracked pretty easily. It all depends on what you are using it for I suppose.
Square Wheels? mechanicalbrain Technical Discussion 11 08-01-2006 17:34
[OCCRA]: 2" aluminum square tubing.. mostunsuspected OCCRA 5 13-09-2004 19:08
Square Root bludstayne Programming 3 14-02-2004 14:48
Center Square Rack Scoring archiver 2000 2 24-06-2002 00:09
Square Rack Sketch archiver 2000 1 24-06-2002 00:09
