Go to Post shhhh...our robot is in a bag now, it won't hurt anyone till the milwaukee wisconsin regional. hopefully it won't be fiesty. don't wake it. - Toatekua [more]
Unread 13-01-2007, 14:06
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Dampening function for driving.
Our driver this year wants a kind of "transmission" in the programming, where if he has a switch up the speed is halfed(or any other number I suppose) for both motors. Or if it's down it drives normally. I have the function all set for the switch and everything, what's throwing me off is trying to half the motor speed in arcade drive. I have the entire thing done in tank drive, with the switch "transmission" and everything, the problem is in arcade drive... It's driving me crazy trying to think about it and any help would be appreciated. Thanks.
~Brad.
Unread 13-01-2007, 14:12
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Dampening function for driving.
In general, a good way to alter an output by a constant factor is:
Code:
pwm01 = (pwm01-127)*0.5+127
This will give you half the magnitude of your original output... change the 0.5 to taste. (Also, be careful, and pretend that this is pseudo-code. Because PWM values are stored as unsigned chars, you may get some interested errors with casting when you go in reverse. Maybe cast pwm01 as an int first?)
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 13-01-2007, 14:18
.999~=1
Ahh, I got it. I'll get my outputs from the joystick, then half them... I was trying to find a way to do it incorporating it into the joystick function (x - y + 127 or x + y - 127) type thing. But doing it after I get those number is just as good, thanks.
Scoring function in C mgreene Programming 7 12-01-2007 02:36
Tips for something big....(Driving cross-country) Greg Perkins Chit-Chat 25 25-10-2006 16:02
Loop time for OperatorControl function? Debug blows... Chris_Elston Programming 10 13-02-2006 14:42
Limit_Mix() Function EricWilliams Programming 2 27-07-2005 23:19
Delaying/Dampening motor response cadets Control System 4 05-02-2004 18:27
