Go to Post We want to go out and build something right away. But it is better to think a little bit first. - ChrisH [more]
Unread 13-01-2007, 15:16
Spark Hawk's Avatar
Spark Hawk Spark Hawk is offline
Alumnus
AKA: Patrick
FRC #1111 (Powerhawks)
Team Role: Electrical
Spark Hawk is an unknown quantity at this point
Quick Wiring Rules Question
Hey, we were just going through the electrical rules in the manual, and comparing it to last year, when we saw that the wire restrictions were not there. Are there no restrictions, or are the rules the same as last year? Thanks a ton.
Unread 13-01-2007, 15:23
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Quick Wiring Rules Question
There are restrictions on wire gauge size. Please read section 8, robot rules.
Unread 13-01-2007, 15:26
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Section 8.3.9 should detail all the wiring guidelines and restrictions for this year.
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
8.3..9
<R86> All wires distributing power with a constant polarity (i.e., except for relay module, speed
controller, or sensor outputs) must be color-coded as follows:
• Use red, white, or brown wire for +12 Vdc and +5 Vdc connections.
• Use black or blue wire for common (-) connections.
<R87> 12 AWG or larger diameter wire must be used for all circuits protected by a 40A circuit
breaker.
<R88> 14 AWG or larger diameter wire must be used for all circuits protected by a 30A circuit
breaker.
<R89> 18 AWG or larger diameter wire must be used for all circuits protected by a 20A circuit
breaker.
<R90> 24 AWG or larger diameter wire must be used for connecting sensors such as: switches,
potentiometers, accelerometers, and other sensors. 24 AWG or larger diameter wire must
be used for connecting a vision system to Robot Controller inputs, and for extending the
PWM cables, for the small muffin fans, or for wiring LEDs. It is acceptable to use ribbon
cable smaller than 24 AWG to connect to the 9 pin ports on the Robot Controller.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 14-01-2007, 13:22
Spark Hawk's Avatar
Alumnus
AKA: Patrick
Well... Now I feel really stupid...
Quick Question 3 Minitruck1506 Chit-Chat 0 22-02-2006 16:21
Wiring Rules sparkyone Motors 9 16-01-2006 13:53
Quick question: Animation rules? Yov 3D Animation and Competition 14 14-12-2004 15:23
Quick Question Burgabot Programming 31 02-12-2003 19:22
A quick question Joelster Technical Discussion 6 10-02-2002 09:09
