Go to Post So.... football pizza water game with minibots and megabots? - euhlmann [more]
Unread 13-01-2007, 17:03
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
gear question
How do I find the Center distances if I want to mate a 20Tooth Gear, 16 DP, 14.5 Pressure Angle, with a Pitch Diameter of 1.25in and Outer of 1.375in with a 60 Tooth Gear 16 DP, 14.5 Pressure Angle, Pitch Diamter 3.75in and a outer diameter of 3.875in?
Thanks for anyone who can help me out.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 13-01-2007, 17:31
RichardJames's Avatar
RichardJames RichardJames is offline
Mentor
AKA: Eric
FRC #0296 (Northern Knights (or Northern Ninjas))
RichardJames will become famous soon enough
Re: gear question
the exact meshing distance between two spur gears is determined by adding their pitch diameters, then dividing by two. (basically, you are adding the pitch radii)
Make sure to add about 3/1000s of an inch between your centers as your gears may grind if the meshing is too exact.
In this picture, pitch diameter is referred to as pitch circle:
To design a good mechanical system, you have to design something so simple it almost doesn't work, then increase the complexity until it does.
Unread 13-01-2007, 19:40
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Re: gear question
Thanks I wasn't sure if it was that simple. I thought it was more complicated than that... oh well.
Kevin Li
596 - Sciclones
Quick question regarding the gear tooth sensor... Brad Voracek Electrical 3 12-01-2007 01:07
Question About Gear Boxes CE Mexican Motors 5 19-12-2006 15:14
Gear Tooth Sensor Question (InsrtNameHere) Electrical 2 20-01-2006 02:19
Gear reduction question dmellich Motors 6 25-01-2003 08:54
motor high gear/low gear switch... archiver 2001 6 23-06-2002 23:50
