Go to Post We will be stressed, we will be angry. But we need to hold ourselves to a higher standard, we need to be role models and inspirations to students. - Andrew Schreiber [more]
Unread 13-01-2007, 18:03
baop858 baop858 is offline
FRC #0069 (Hyper)
baop858 will become famous soon enough
Send a message via AIM to baop858
CMU won't track with the RC
I calibrated the camera and it tracks in the java cmu app and the labview software it won't track using with the RC. I don't know what I'm doing wrong, I was able to track fine the last two years. Does anyone else have this problem?
Unread 13-01-2007, 18:07
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: CMU won't track with the RC
Please post more details.
Have you installed Kevin Watson's CMUcam code on the RC? Have your TTL converter connected? Is the camera's red light on? And what are you seeing in the terminal window of the IFI loader? Is it "error 131"ing? Try power cycling.
Good luck
JBot
Aren't signatures a bit outdated?
Unread 13-01-2007, 23:08
FRC #0069 (Hyper)
Sorry for be so vague the first time, the camera is property connected I believe. The camera reaches the searching state, when it pans and tilts and it says it is searching on the terminal window. I believe when it gets this far it means the camera is property connected and has been initiated.
Unread 13-01-2007, 23:20
JSonntag JSonntag is offline
FRC #0486 (Positronic Panthers)
JSonntag is on a distinguished road
Send a message via AIM to JSonntag
1. Make sure that the color values are correct in the code.
2. If you are using Kevin's code, the way the camera is mounted matters. If you mount it with the on-off switch near the top, you have to go and change a few signs in your code or else it will always try to move away from the light instead of centering on it.
Unread 14-01-2007, 17:00
FRC #0069 (Hyper)
I realized what I did wrong. In labview the camera settings were not default(like brightness and color gain), it was from last year. So I just had to adjust the camera settings on the program. Thanks for the help everyone
Unread 18-01-2007, 15:46
sniggel sniggel is offline
FRC #2051
sniggel is an unknown quantity at this point
what setting do we need to change in the code if the power is mounted to the top
Unread 18-01-2007, 15:48
FRC #2051
what settings do we need to change?? we have tried changeing the tracking.h pan_rotoation_sign_default and that hasnt worked for us yet
CMU CAM2 won't track! 1594code Programming 2 19-12-2006 22:20
CMU 2 cam with Vex Nathan Technical Discussion 13 11-11-2006 20:55
Need help with easy c about the CMU . Ami Schwartz Programming 2 15-01-2006 10:58
Need Help with Encoder - Won't Count Clicks Kingofl337 Programming 5 16-02-2005 18:30
