Who has the tidiest wiring?
Post a picture of what you think is the best wired robot
Team 2200: 2007 rookie year, 5 days after kickoff. |
Re: Who has the tidyest wireing?
You wiring is pretty tidy. But I would say you should do something about that drive shaft just floating there. You should probally put in a bearing block there.....
in the works.
do you plan on driving all four wheels? Those kit wheels are pretty grippy and it doesn't look like you'll have an easy time turning.
im going to do basic wiring hopefully tomorrow
i will post a pic then /forest |
Some of my favorites from past years...
Greg, do you know what that black (plastic?) material is in the first pic? Where do you get it? What are the specs, thickness, weight, etc.?
We have always used plywood for our electronics board because it is cheap, easy to cut and screw stuff to and also non-conductive incase someone makes a mistake and drops a screw/wire/etc. I would like to try something new and lighter this year. Does anyone have a favorite material they can recommend? |
Where are the labels?
#10
1/4" ABS Plastic is what you see there. Available pretty much anywhere. We got ours from McMaster. It is about the nicest, lightest and easiest thing we have found to work with. Everything else is either too heavy, too thick, or too ugly for our tastes. Here are some more pictures for ideas and inspiration. There are plenty of better examples out there, too. I have always been inspired by teams 60 and 207. ![]() ![]() ![]() ![]() Last edited by Travis Covington : 14-01-2007 at 05:30. |
#11
There efficiency that is Last edited by Corey Balint : 14-01-2007 at 23:45. |
#12
Re: Who has the tidiest wiring?
We usually use either plexiglass or lexan (idk which)
I think ours is the tidiest board ![]() |
#13
Hahahahahaha! Now wire it up and keep it looking that tidy!
#14
.Last edited by RyanN : 14-01-2007 at 11:41. |
#15
Neatness of wiring has often taken a back seat for available space and time remaining. But our team has done better in recent years. Though I have a suspicion that is is only because we have allotted more room for electronics, which I'm very thankful for.
| Who has the camera working? | cvbritton | Programming | 43 | 28-01-2007 13:46 |
| who has the best | eric195 | General Forum | 4 | 25-03-2004 16:13 |
| Who has the coolest avatar? | Alex Cormier | Chit-Chat | 35 | 06-02-2004 18:19 |
| Who has won in the past? | Petey | Website Design/Showcase | 5 | 02-02-2003 23:52 |
| Who has the best computer? | James Crivellone | Chit-Chat | 59 | 12-03-2002 20:34 |
