Go to Post And who knows, maybe one day you'll prove the impossible possible! - MissInformation [more]
Unread 13-01-2007, 23:30
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
PWM 13-16 Replacement Code
For those who are using interrupts and don't like the jittery PWM outputs on channels 13 through 16, I've written replacement code for IFI's Generate_Pwms() function that uses the built-in CCP hardware to generate super accurate PWM pulses. The code also allows you to set the neutral point and gain for each output channel, giving you complete control of your servos and motors. As an example, this code allows you to map the entire 0-255 PWM range into a small fraction of the normal travel of a servo arm, which would come in handy if you wanted to make a more accurate range calculation to the green light.
I'd like to do a quick beta test to find any bugs or documentation problems before posting it to my web page. If you're interested in helping out, you can download the code here: http://kevin.org/frc/frc_pwm.zip. If you find any problems with code or documentation, please leave a message here.
-Kevin
Edit: Changed link to point to released code.
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Vex start up code run PWM outputs without Rx intellec7 Programming 3 05-05-2006 23:29
Pwm 11, 12 and CMU code Chris Bright Programming 3 01-02-2005 19:34
Victor Replacement JamesCH95 Electrical 4 15-12-2004 20:12
Replacement Parts archiver 1999 0 23-06-2002 22:01
replacement gears joni_m Technical Discussion 1 22-01-2002 18:01
