Go to Post Consider how nature does this, and emulate. Nature usually has a pretty good algorithm. - DonRotolo [more]
Unread 14-01-2007, 00:44
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
Strange noises from the BaneBots gearbox/CIM combination.
We just test assembled our CIM/Banebots transmissions.
One unit purrs like a kitten. The other unit growls like a lion.
We disassembled the noisy assembly several times, and swapped CIMs but it still seems to have something not quite right. At one point the motor actually stalled.
We tested the CIM independantly and it seems fine.
At one point, when the CIM was off the gearbox, there was a distinct "crunchiness" when hand turning the gearbox output drive shaft.
This unit was brand new, and we'd never even mounted it to a chassis.
What do we do?
Do we try to dissasemble the entire planetary drive and try to clean it, or see if FIRST can get us a replacement, or do we need to go directly through BaneBots? It kinda puts a crimp in our progress.
Anyone else have a noisy drive?
Phil.
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Unread 14-01-2007, 00:54
clean399's Avatar
clean399 clean399 is offline
Mr. Clean
AKA: Nick Hayes
FRC #0399 (Eagle Robotics)
clean399 is a jewel in the roughclean399 is a jewel in the roughclean399 is a jewel in the rough
Send a message via AIM to clean399
Re: Strange noises from the BaneBots gearbox/CIM combination.
Check to make sure there is a sufficient amount of grease in your gearboxes because that could be a problem and if that doesn't work I would say carefully slide out the gears and make sure they are aligned.
Unread 14-01-2007, 02:53
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
What do we do?
Phil.
You might be interested in this post:
http://www.chiefdelphi.com/forums/sh...5&postcount=38
Check out items 2&3. If this doesn't help contact BaneBots
Christopher H Husmann, PE
"Who is John Galt?"
Unread 15-01-2007, 08:53
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Ours did this too. The black pinion spacer is a bit too long. Grind or file it down ~ 1mm.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 15-01-2007, 09:18
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Studying for an english exam?
Just file a very small amount of the peice repeatedly until it becomes the correct length.
Unread 15-01-2007, 11:15
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
Team Role: Mechanical
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
This happened to us too.. It just turned out for us that we did not have all 4 screws on the plate down all the way.. so check to see if you have all of your screws torqued down.
opening up the BaneBot gearbox to install the CIM motor jskene Motors 9 22-01-2007 11:12
pic: Bike Cim + 56 mm gearbox NK2007 Extra Discussion 7 15-01-2007 01:10
42 mm Banebots Gearbox Hunter Motors 9 13-01-2007 21:52
2007 BaneBots 52mm Gearbox is posted ! Ed Sparks Inventor 3 09-01-2007 07:38
Gearbox that can be used inline with a CIM bombadier337 Motors 3 11-03-2005 22:05
