Go to Post Go get Al, he probably isn't busy! - Jimmy Nichols [more]
Unread 14-01-2007, 14:41
elect.378 elect.378 is offline
FRC #0378
elect.378 is an unknown quantity at this point
Robot Arm Extension
Does anyone know if at any time your robot's arm or wings can extend outside of the 72" restriction and then come to rest inside the 72"?
Unread 14-01-2007, 14:44
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Re: Robot Arm Extension
When you're in your home zone, yes, you may extend however far you want.
Unread 14-01-2007, 14:47
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Home zone only. Not sure I'd go in, unfold, and go out. Stay in the 72" box if possible if you'll be deploying/undeploying often.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 14-01-2007, 18:42
eugenebrooks eugenebrooks is offline
AKA: Dr. Brooks
no team (WRRF)
eugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond repute
You are not allowed to think outside of the box,
but you are allowed to think diagonally in the box.
http://forums.usfirst.org/showthread.php?t=1121
Unread 14-01-2007, 19:03
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
I don't understand what people keep saying about diagonally in the box. The only way that is possible is if your arm is on an angle from the rest of your bot, and to what advantage would that give you. Its not like when your robot moves in said box that the box doesnt move with it. You are confined to the box no matter what way you face. So your arm can't be any further out than 72 inches unless the arm itself is diagonal from your robot, which to me seems pretty pointless.
Unread 14-01-2007, 19:17
Billfred's Avatar
Billfred Billfred is offline
Actually, the box doesn't have to move with the robot. Putting the robot diagonally in the box is entirely possible--you define where your robot is in relation to the box, not the inspector. Quoth the GDC:
Originally Posted by GDC
The intent of Rule <R12> is that the robot must be able to fit within a 72" x 72" virtual box at all times. The orientation of the robot within the box is inconsequential.
If you can fit the whole thing, robot and all, into a 72" square, your arm can be as far out as you want. In theory, it could go as far out as 101 inches and change, under the Pythagorean Theorem. (Obviously, there are other variables afoot in that, like fitting the rest of your robot.)
Unread 14-01-2007, 20:03
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Rookie Year: 2000
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
Originally Posted by FIRST Game Manual
While outside of its HOME ZONE, a ROBOT may expand up to a maximum width of 72 inches and depth of 72 inches.
If I am reading this correctly I believe you are incorrect. It is a 72" square at ALL times you aren't in the home zone. I am unsure what you have read to lead you to believe that this will allow you to just fit the bot in the 72" square once and then extend to a 101" later on in the match.
Unread 14-01-2007, 20:25
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Put your robot in one corner of the 72" square box and rotate it 45 degrees, so it is facing the opposite corner of the box.
Now do you see how it can be more than 72" long?
Unread 14-01-2007, 21:24
NoSkaOnTheRadio's Avatar
NoSkaOnTheRadio NoSkaOnTheRadio is offline
Team 1757 Alumnus
AKA: James Carney
FRC #1757 (The Big Green)
Team Role: Mechanical
NoSkaOnTheRadio has a spectacular aura aboutNoSkaOnTheRadio has a spectacular aura about
Send a message via AIM to NoSkaOnTheRadio
i think someone should draw a picture of this .
Unread 14-01-2007, 21:39
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Cuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond repute
Send a message via AIM to Cuog
Done:
I love my tablet
KK4KQO
http://voltair.us
Too many projects, too little time.
Unread 14-01-2007, 22:10
bobmonkey836's Avatar
bobmonkey836 bobmonkey836 is offline
BobMonkey07
AKA: Jeff Powers
FRC #0836 (Robobees)
bobmonkey836 is on a distinguished road
that thar's some gud drawin skil!
Solution to life's problems: "CTRL", "ALT", "DELETE".
"CTRL"+"Z" Saved my life.
Approximately Normal
2007 Annapolis Regional at USNA!!
Management is doing things right; leadership is doing the right things.
- Peter Drucker
Unread 15-01-2007, 08:41
FRC #1360
inconsequent: lacking worth or importance.
By this defination the orientation of the robot does not have an importance or worth. Therefore it doesn't matter which way the robot faces it would still be out of the box. Just think about it, if they meant it. they would have to give everyone a direction in which this virtual box faces.
Orginally posted by shamuwong
Actually, the rule book specifically tells teams not to "lawyer" the rules and such. By that, they mean stick to the spirit of the competition and don't look for loopholes to get the advantage through devious game play.
I think innovation refers not to creativity in interpreting the rules, but rather, the game.
Don't read too much into it. 72 inches is 72 inches regardless of what way you face your robot.
Unread 15-01-2007, 09:24
bobotics319 bobotics319 is offline
AKA: Andrew Levasseur
FRC #0319 (Bobotics)
Team Role: Communications
bobotics319 is an unknown quantity at this point
My interpretation of the rule is that as long as you can take your fully extended robot and put it in a 72x72 inch box (regardless of robot orientation), you're legal.
I think FIRST needs to make some clarifications.
Arm Extension Question predator_hunter Rules/Strategy 6 11-01-2007 21:10
ARM GEARING ON ROBOT kshag Technical Discussion 11 27-02-2005 21:02
**IMPORTANT FIRST EMAIL**/Robot Ship Extension News with Season Information and Upda miketwalker FIRST E-Mail Blast Archive 0 13-02-2004 18:02
Robot Controller arm David Kelly Technical Discussion 0 28-06-2001 16:37
