Go to Post ...remember RAID 0 is a trap. - Sperkowsky [more]
Unread 14-01-2007, 15:07
feliks_rosenber's Avatar
feliks_rosenber feliks_rosenber is offline
Félix
AKA: Mentor of Teams #2217 & #2669
FRC #2217 (FOMHA & KY Bots)
Rookie Year: 2007
feliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the rough
Send a message via MSN to feliks_rosenber
Different approach from a rookie player
Hello !
I'm a rookie in a rookie team and my team hasn't developed its final strategy yet.
I look for some advice as to the strategy of the play. As far as I know there's no rule that prohibits blocking other robots and preventing them from scoring rows during the whole game. Including the autonomous period of game.
That as long as you do not intend to cause them any damage.
This brought me the idea , that maybe it's not going to pay off if you just put those keepers because the other team might do it as well.
So I thougt about some different approach to this question (I'm not going to reveal my team's strategies all I'm doing is I'm sharing an opinion).
And my opinion is that the game might be just decided in other ways.
Let's suppose that 1 robot in the alliance scores a keeper and 1 other robot keeps this robot from bumping into enemy robots whereas the 3rd blocks 1 of enemy robots from scoring a keeper.
What do you think ? First, is it legal ?
Do you think that there's anything in what I say ?
Unread 14-01-2007, 15:14
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Different approach from a rookie player
Legal, as long as no safety or interaction rules are broken (see Section 7). Doable? Slightly different question. Can you work with your partners this way? If so, go for it. If not, hope your opponents don't play this way. The biggest problem is not seeing which side you'll be hit from by defense bots. (not terribly big) The other problem? Actually placing the keeper.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 14-01-2007, 15:16
RichardJames's Avatar
RichardJames RichardJames is offline
Mentor
AKA: Eric
FRC #0296 (Northern Knights (or Northern Ninjas))
RichardJames will become famous soon enough
There is definitely merit in this sort of strategy - effective blocking is always a skill which can change the outcome of a match. Some robots are designed to be the "blocker" bot on a team, the problem is that if two or even three robots oriented towards blocking end up on a team together, you`re in a bad situation. Don`t forget that seeding rank is determined first by number of wins, losses, and ties, and then is further sorted by the number of qualifying points your team has received (aka the average of the losing team`s points scored in all of your seeding matches). Thus, even if a team wins by mostly blocking, they will be usually seeded below a team that wins by mostly scoring.
Anyhow, I think it`s more exciting to score and really play the game then to rely on a winning strategy. In the past my team has always opted for the most fun bot design over the most likely to win design.
To design a good mechanical system, you have to design something so simple it almost doesn't work, then increase the complexity until it does.
Unread 14-01-2007, 15:20
theycallhimtom theycallhimtom is offline
AKA: Tom Conerly
FRC #1540 (The Flaming Chickens)
theycallhimtom has a spectacular aura abouttheycallhimtom has a spectacular aura abouttheycallhimtom has a spectacular aura about
Send a message via AIM to theycallhimtom Send a message via MSN to theycallhimtom
Well the score of the losing team only matters if two teams are tied in terms of wins and losses. So low scoring only hurts you in terms of a tiebreaker.
For the strategy I might use it if there is a really dominant scorer on my team I want to protect but other than that I probably would not bother.
Unread 14-01-2007, 15:22
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
You know, that sounds like a really good idea.
Anyway, be careful that you don't ram the other robots when you're dashing across the field to get in their way. Maybe ultrasonic rangefinders, etc could be useful.
Actual quote from 2005:
"Ramming in autonomous? That's not even a rule, is it?"
After one of the programmers forgot to take out his test autonomous code,
if (time < 3 seconds) { FULL SPEED AHEAD! }
Yes, 868 programs in English.
Unread 14-01-2007, 15:54
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Last year's rulebook doesn't differentiate between teleoperated blocking and autonomous blocking. At the driver's meeting in Atlanta we were told that high speed long distance ramming in autonomous would not be penalized unless it occurred within a starting box, as that was the only way they could objectively judge intent. At our regional (BAE) ramming was not called in autonomous. I'm sure this will be clarified in the Q&A.
To the thread starter, I would suggest going back and looking at some of the discussions on this forum that occured last year regarding autonomous. Essentially, blocking last year in autonomous was a very viable strategy, as there was a wide open field. In Atlanta with the Championship title on the line the alliance led by 25 (one of the most talked about robots), decided to go completely defensive and keep the alliance led by 296 from scoring. Unfortuneatly those pesky CMUcams did their jobs, and 296 and company still scored.
Also, autonomous scoring may be difficult this year, or it may be easy, we simply don't know yet. If it is relatively easy, a high seed will most likely be searching for a more defensive robot for his/her second pick. Reason being the serpentine draft tends to get rid of the most effective scorers before the they get to pick again. So a decent scorer with above averasge defensive abilitilites may be a decent bet at getting picked during the second round. We'll see come March...
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 14-01-2007, 16:21
Félix
Rookie Year: 2007
Conclusion: Better look for some other strategy
Thanks for the comments but I think I'm gonna consider other strategies because there are two main reasons why this is a somewhat problemetic choice:
No guarantee that the robot will interfere with other alliance's robots because they are equiped with the CMUcams and there's always the possibility the other alliance thought about such defensive play and acted accordingly writing their algorithms.
Second, it might be as well in the end a matter of how many points you score rather than how you think the other alliance would play.
In reply to iCurtis:
Could you share some more experience with us please ?
I wish my team would make it to Atlanta
As it seems now , I would be satisfied with its making it to Tel Aviv at least
Unread 14-01-2007, 17:23
Cyberguy34000's Avatar
Cyberguy34000 Cyberguy34000 is offline
Scout-Master
AKA: Chris
FRC #0662 (Rocky Mountain Robotics)
Team Role: Scout
Cyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond repute
Send a message via AIM to Cyberguy34000
Re: Conclusion: Better look for some other strategy
No guarantee that the robot will interfere with other alliance's robots because they are equipped with the CMUcams and there's always the possibility the other alliance thought about such defensive play and acted accordingly writing their algorithms.
If you look at most teams from last year, autonomous programming hasn't quite been advanced enough to do anticipate the defensive play you were talking about. Most of the autonomous programs consisted of drive forward, aim, shoot. A simple ram straight ahead into the opponent shooter strategy actually worked pretty well for deterring many teams from scoring. It was very simple to write a program to just turn on two motors, as compared to the program to track the vision targets. The only times that I personally saw teams counteracting the defense strategy was in the Florida regional finals, where robots would launch out and cover the alliance shooter robots from getting rammed. But this event was fairly rare. This year, a simple "ram the rack" could easily screw up the most elegantly planned autonomous program.
Don't discount the effectiveness of a simple defense.
-Chris
I love deadlines, I love the wooshing sound they make as they fly by. - Douglas Adams
They who would give up an essential liberty for temporary security, deserve neither liberty or security. - Benjamin Franklin
Unread 14-01-2007, 17:43
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Rookie Year: 2007
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
Why don't you build a robot that drives aroung, gets in the way, and then deploys two twelve inch ramps at the the end of the match so that you can lift the rest of your alliance.
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Unread 14-01-2007, 17:44
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Defense is going to be huge this year, even more so than last year. Scoring the inner tubes is not an easy task, arguably harder than shooting the poof balls. I think a very effective alliance partner would be a strong defensive robot with ramping capabilities. We considered building a strong defensive robot for this years game because it would be a very successful strategy. I always love good defensive robots, and would like to build one.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 14-01-2007, 18:37
Netherlander Netherlander is offline
FRC #1006 (Fast Eddie Robotics)
Team Role: Electrical
Netherlander is an unknown quantity at this point
My team and I have always felt that a scoring robot with a strong durable mobility system should be just as adept at scoring and defense why not do both.
Unread 15-01-2007, 14:42
rwwman50's Avatar
rwwman50 rwwman50 is offline
FRC #2016
rwwman50 is on a distinguished road
Send a message via AIM to rwwman50
Im also on a rookie team # 2016 and we considered this sort of robot but eventually desided that like Netherlander said a robot could do both just as easily a s one and would create a much higher point differential (not sure if thats proper spelling)
Victory at all costs,
Victory despite all the terror,
Victory however long and hard the rode may be
-Winston Churchhill
So this is how liberty dies,
to showers of thunderous applause
-Star Wars Episode III
WAR is PEACE
FREEDOM is SLAVERY
IGNORANCE is STREGNTH
-Orwell 1984
Unread 15-01-2007, 15:59
Revolverx7's Avatar
Revolverx7 Revolverx7 is offline
Ninja
AKA: Sanders
FRC #0358 (Robotic Eagles)
Team Role: Driver
Revolverx7 is on a distinguished road
Send a message via AIM to Revolverx7
I feal that defence this year isn't going to be as important as it was last year, or even the year before with stacking tetras. Its going to be very difficult for a defensive bot to effectively drive around the rack and see their robot enough to manuever around blocking.
I think its going to be more of score your side of the rack and then protect it. Maybe throw in a spoiler if you have the capabilities.
2006 SBPLI Regional Champions (with 271 & 870)
2006 UTC Finalist (with 181 & 585)
2005 SPBLI Regional Chairmans Award
2005 SBPLI Regional Champions
2005 Philly Regional Finalists
Help from a CS:S player Josh Goodman Chit-Chat 1 12-12-2006 00:24
afterthoughts from a rookie gondorf General Forum 14 16-05-2006 08:09
Thanks from a 2006 Pre-Rookie Dan Zollman Thanks and/or Congrats 2 15-05-2005 18:10
[ECDU]: more people from different teams Michael Leicht FIRST-related Organizations 4 21-07-2004 20:46
Looking from a different point at "Fixing" punarhero General Forum 27 18-03-2003 18:41
