Go to Post Either way, I'll stay a FIRSTer for life. =) - Adare180 [more]
Unread 14-01-2007, 17:11
edthegeek's Avatar
edthegeek edthegeek is offline
AMHS/Case Western Reserve Universit
AKA: Eduardo Arellano
no team (TKO)
edthegeek has a spectacular aura aboutedthegeek has a spectacular aura aboutedthegeek has a spectacular aura about
Send a message via AIM to edthegeek
Attempting to Cut BaneBot 56mm Shaft
Does anybody know the material of the shaft in the BaneBots 56 mm gearbox? And has anybody tried cutting/truncating it and have any tips. We have a small Smithy mill that we can use, but don't know if this is the best way to cut it.
"You do realize that most of the substances that you are inhaling right now are considered toxic in the state of California"
-Paolo to me while I am covered in Teflon and soldering.
"Stupid Chinese 6011 Alloy is stronger than we thought."
"Comrade, your sacrifice brings honor to the motherbot."
Unread 14-01-2007, 17:28
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Re: Attempting to Cut BaneBot 56mm Shaft
The shaft is steel. BaneBots has been monitoring these boards lately so maybe someone there will offer more detail on the type of steel and what hardening (if any) is used.
It is generally not a good idea to side load a planetary gear set like this, so the set up for your cutting operation should include supporting and clamping the shaft on both sides of the cut to minimize side load.
There may be a safe, reversible method of disassembling the unit so that you can securely clamp the shaft and final spider assembly for cutting, but since I haven't attempted that I can't offer advice -- maybe Dr. Joe or (again) someone from BaneBots can, or maybe you'll need to experiment.
Purely out of curiosity, why do you want to cut the shaft?
Richard Wallace
since 2003
Unread 14-01-2007, 17:57
edthegeek's Avatar
no team (TKO)
We want to cut the shaft for several reasons. One, the shaft sticks out way past the walls of the chassis and the 28x38 box. Two, if we leave it long, it interferes with the motion of the chain and the position of the drive sprockets.
Unread 14-01-2007, 18:10
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
our team would be cutting them off (assuming 4 transmissions and the sprocket is mounted up against the transmissions) to shave 2/3 of a pound off the robot...and it still would not be enough....
Unread 14-01-2007, 18:34
Kirk Kirk is offline
FRC #0254
Rookie Year: 1997
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Get a pneumatic cutoff grinder. It will make quick work of the shaft. You can also use a regular 4" electric grinder with a cutoff wheel in it. Just keep a eye on the shaft temperature.
Unread 14-01-2007, 18:41
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
We opened our 42mm up today. Once you've got the four screws out, everything's pretty easy to take apart.
That was the little gearbox, not the 56mm. I can't vouch for the assembly of the 56, but there are good odds that it's the same, so if you just go slow and make sure you don't lose or break anything, you should be fine.
Before you close it up, make sure you clean and lube it up if you got any dirt in the gears or lost a lot of the grease.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 15-01-2007, 08:51
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
It's quite easy to remove the output shaft from the gearbox.
Remove the 4 2.5mm hex head screws around the periphery of the geabox on the output side, and pull the output side endcap off. You can then undo an external retaining clip on the inside end of the shaft, and pull the shaft off.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
BaneBot Transmission Encoder Daru Motors 9 27-01-2007 23:17
Banebot 2 motor adapter Ben Piecuch Motors 5 17-01-2007 16:06
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? VEN Technical Discussion 4 11-01-2007 14:45
Big Shaft to Little Shaft? Anton Abaya Technical Discussion 7 21-01-2002 19:27
