Go to Post the jocks may have muscle, but we have extruded aluminum :D - [527]phil [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 15-01-2007, 13:17
team877's Avatar
team877 team877 is offline
FRC #0877 (Cub Robotics)
team877 is an unknown quantity at this point
Configuring Labview code to easyC
Hi there, after lots of troubleshooting I got to where i should save labview to easyC code and when i did that it did not save it as a .ECC file it saved it as a configuration setting. Therefore when i tried to run it on easyC it wasnt there. If you can help me settle this problem it would be greatly appreciated.
Thank you....
Adam, Programming
Unread 15-01-2007, 13:24
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Re: Configuring Labview code to easyC
Once you load the labview file into easyC it will save those values in the current project.
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Unread 15-01-2007, 13:28
team877's Avatar
But doesnt it have to be saved as a easyC format to do this in the first place???
Unread 15-01-2007, 13:40
Kingofl337's Avatar
AKA: Adam
Rookie Year: 1998
Oh, I get it, can you e-mail me that file to amartin "at" intelitek.com
Unread 15-01-2007, 17:08
team877's Avatar
I sent out the email to your email
Unread 16-01-2007, 01:11
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
When you guys get your issue resolved, do you mind posting your results?
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 16-01-2007, 09:21
Kingofl337's Avatar
AKA: Adam
Rookie Year: 1998
Labview changed the file to a .ini from a .ecc. So just rename the file labview generates to a .ecc and easyC will load it. We will update easyC in the next build.
easyC Mechanum Drive Code Kingofl337 Programming 0 12-01-2007 23:48
EasyC: Execute code before autonomous Greg Marra Programming 7 07-01-2007 21:30
EasyC Default Code Team 1649 Programming 13 29-01-2006 11:52
LabView Gear Tooth Sensor Code SkiRacer LabView and Data Acquisition 2 17-01-2006 03:53
VS.NET 2003 Configuring D.Viddy Programming 5 20-01-2004 21:24
