Go to Post It's easy to get overwhelmed. Don't get overwhelmed, just keep working at things a little bit at a time. (Oh, and don't forget to have fun!) - DominickC [more]
Unread 15-01-2007, 14:04
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
More questions about Dewalt transmissions
Our team is trying to come up with a way to attach an axel to the output shaft of the dewalt transmission, and we would like to know how other teams have done it or suggestions to do this. Please post pics of possible.
I have read the transmissions can shift on the fly, but how well do they shift under a heavy load? If we were in second gear and started to push against annother robot and shifted down to first gear, would the transmissiom hold up or break?
Thanks
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 15-01-2007, 14:42
Joe Johnson Joe Johnson is online now
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Re: More questions about Dewalt transmissions
Thanks
If my memory is not playing tricks on me, back in the early stages of working with the Dewalts, Chief Delphi built a prototype chassis with the wheels.
we made a steel tube with a stepped inside diameter. The tube screwed on to the output shaft of the Dewalt and we could put the Left hand chuck screw in through the other side. We also had a cross pin that we pressed in after attaching to shaft with the LH screw. This pin transferred torque to the wheel.
We didn't support the shaft other than the support that the Dewalt gave it.
It worked okay, but it was marginal in my opinion. I really can't recommend it unless you support the end of the shaft away from the Dewalt.
Even with the support, it seems to be less than ideal. If you have a good reason to do this, it may be worth the bother, but in general, I suppose a chain will serve you better.
Joe J.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Unread 15-01-2007, 16:47
AJ R's Avatar
RoboGeek
Thanks for the idea. Would you know what thread size is on the out put shaft on the dewalt transmission?
Thanks
AJ
Unread 15-01-2007, 17:38
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
We don't use the yellow housing. We custom mount the naked transmission instead.
We use this for the final drive. It replaces the DeWalt 0.3" x 0.25" double-D disk so that we can drive a 1/2" keyed shaft.
Dewalt transmissions Gabe Technical Discussion 19 01-01-2007 01:55
Inventor Files for Dewalt Transmissions! Dylan Gramlich General Forum 2 29-12-2006 01:29
Dewalt XRP Drill Transmissions available - discount pricing Stu Bloom General Forum 0 17-10-2006 09:39
DeWalt Transmissions - XRP Drill source !! Stu Bloom Technical Discussion 2 13-01-2006 22:34
Dewalt Transmissions Joe P Technical Discussion 9 09-09-2004 21:07
