MpLab won't compile the project......
i keep getting the error C:/.............../ cannot find "stdio.h" failed build big problem, help would be hugely appreciated...... |
Re: MpLab issues!
In the IDE, right click on the project in the MCW window (name should be something like default.mcp or gyro.cmp), and select "Build Options". Make sure the Include Path and Library Path match your C18 installation.
Re: MpLab issues!
Kaszeta is right, its your include path. From the menu you can also select "Project->Build Options->Project".
I attached a picture of where the include directory is set in my project. Brian |
Thanks guys, it worked
| Fundraising Issues... | IraJason | Fundraising | 32 | 04-09-2006 16:03 |
| Venue issues... | David Brinza | Regional Competitions | 8 | 28-03-2006 07:55 |
| MPLAB Issues | jcatt | Programming | 3 | 02-02-2006 17:49 |
| Issues with MPLAB 7.30 | gnirts | Programming | 4 | 25-01-2006 22:57 |
| using the MPLAB IDE MPLAB SIM simulator | WizardOfAz | Programming | 1 | 03-11-2003 01:24 |
