Go to Post Building sustained excellence happens when you start with the right pieces at the top...and pick up the rest of the pieces on your way. - Jared Russell [more]
Unread 15-01-2007, 23:13
TJ4nier TJ4nier is offline
Professional Stress Monger
AKA: TJ
FRC #2168 (Fitch CyberFalcons)
Team Role: Leadership
TJ4nier is an unknown quantity at this point
Send a message via AIM to TJ4nier
Servo Strength
How much weight could one of the servos from this years kit hold? The part of our robot that I'm assigned to requires a servo to hold it still until told otherwise, but I'm not sure if that will work considering the size of the part compared to the servo.
But, hey, maybe it has some hidden strength deep within that teeny little black box?
Professional Graciousism?
Gracious Professors?
Profess Graciousness?
No. Listen to the "W-Dawg" Flowers!
It's GRACIOUS PROFESSIONALISM.
Championship Division Strength Rob Championship Event 26 06-04-2006 18:19
Strength difference between aluminum sdcantrell56 Technical Discussion 3 21-01-2006 10:07
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Strength of welds on gears sanddrag Technical Discussion 16 30-01-2004 17:32
shear strength Andrew Dahl Technical Discussion 1 14-02-2002 10:02
