Go to Post You know you've overdosed on FIRST when you hear people yell "CHARGE" and you get confused and lost when you look and see baseball and not robots - thatphotochick [more]
Unread 16-01-2007, 00:00
d.courtney's Avatar
d.courtney d.courtney is offline
AKA: David
FRC #0781 (Kinetic Knights)
d.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud of
Question Concerning Operator Interface Inputs
So, I don't know to much about custom inputs to the OI, and I thought I would ask you guys before I did something terribly wrong. I want to know how (if its even possible) I would have a rotational sensor, encoder, or gyro, be an input for the OI, there were a few ideas I had this for. just wondering if it was possible given our OI or if I was wasting my time.
Thanks
David Courtney
edit: I realize this is in the programming section, not the control/OI section, thats because the question was mainly from a programming standpoint, ie what special programming would be required.
Unread 16-01-2007, 00:18
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
Re: Question Concerning Operator Interface Inputs
you could have a potentiometer and possibly a gyro if it has the proper output but an encoder would be difficult. What exactly are you trying to do?
1139 Alumni
Unread 16-01-2007, 06:59
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The OI is designed to accept two kinds of inputs. One is a variable resistor from ~2K to ~100K ohms; that's what the joysticks are. The other is a contact closure to ground; that's what the buttons are. You can provide a voltage between 0 and +5 volts on the joystick input pin and have it work.
There is absolutely no programming involved in connecting things to the OI. It is what it is, and we can't change how it works.
For a rotation input, a simple potentiometer will work. If the control needs to spin continuously, use a pot without an end stop. There is some programming you can do here, to accommodate the sudden jump from one end of the scale as the potentiometer wraps around. If your rotation rate is slow enough, you might be able to get away with using a quadrature sensor and a pair of digital inputs, but I wouldn't count on it.
Unread 16-01-2007, 14:34
d.courtney's Avatar
AKA: David
The pot switch I did think of and it likely would work, I was just wondering if there was anything out there that is infinite, and just returned a +/- degrees of rotations just add the value to an int, that way I could know say if the switch had been turned 720 degrees and have a different effect then if it was turned 360 degrees.
Its purpose would be to aid the driver with controlling an attachment, if we end up going with one of our ideas we are considering.
2005 Operator Interface mtaman02 Control System 0 11-01-2007 19:12
operator interface tml240 Electrical 5 10-02-2004 17:50
Operator Interface code RiotingNerd Programming 5 07-02-2004 21:13
Operator Interface Heads Up Madison Robotics Education and Curriculum 6 11-12-2002 06:59
Operator Interface Improvements Dan Technical Discussion 3 18-02-2002 19:23
