Go to Post It's a shame that this is likely the year that sacred ground will be touched by that unworthy drive :rolleyes: - AdamHeard [more]
Unread 16-01-2007, 13:58
Lablabla Lablabla is offline
AKA: Carmel Barak
FRC #1957 (LighTeam)
Lablabla is an unknown quantity at this point
Green light Case
Hi,
Can anyone tell me where can I find the pdf file which has the measurements of the green light box, with the drawing and everything?
Thanks,
Carmel
LighTeam #1957
2006 GM/Technion Israel Regional Finalist (Robot: W.Bob)
Attending: Israel GM\Technion Regional (Robot: Laika)
Unread 16-01-2007, 14:02
Blair Frank's Avatar
Blair Frank Blair Frank is offline
Writer and Alumnus
FRC #0852 (Athenian Robotics Collective)
Blair Frank is a jewel in the roughBlair Frank is a jewel in the roughBlair Frank is a jewel in the roughBlair Frank is a jewel in the rough
Re: Green light Case
You can find it on the FIRST website with all of the other drawings for teams here.
Also, A hint: If you don't want to use solid aluminum (like it specifies), just line the box you make with aluminum foil. You'll get a similar brightness level to that of the pure aluminum.
Proud alumnus of Team 852, the Athenian Robotics Collective.
Pneumatics in a nutshell: Put together an elaborate series of pipes, canisters, cylinders, valves and hoses; then fill that system with highly pressurized air, and hope that it doesn't blow up in your face.
Unread 16-01-2007, 14:05
AKA: Carmel Barak
Thanks!
That's exactly what I was looking for
Thanks for the hint
EDIT:
Now that I look at this, it looks as if the casing is something we should have got in the kit of part.
is it?
or we need to built this one?
LighTeam #1957
Unread 16-01-2007, 14:13
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
you get the cold cathodes and the front lens in the kit......you have to build the rest from tinfoil covered wood or aluminum.
/forest
Unread 16-01-2007, 14:18
AKA: Carmel Barak
Alright,
How do you power this thing?
while it out of the box, no problem, 12 volt power source, but when in the closed box?
LighTeam #1957
Unread 16-01-2007, 15:25
fimmel's Avatar
AKA: Forest Immel
i would make a terminal block on the inside of the box. then wire all of the CCs to that and then attach a length of wire from the terminal block to a battery or even better a 12v power supply (old computer power supply) also dont forget t add ventilation holes in the box.....the CCs and their transformers will get warm.
/forest
Unread 16-01-2007, 15:37
AKA: Carmel Barak
thanks,
another question
I'm looking at the pdf file for a long time, trying to understand to final mesurements of the complete box
16"X8"X???
1" as seen at square #3? what's that aluminum block? (#22)
and what's the aluminum angle (#26)
Thanks,
Carmel
LighTeam #1957
Unread 16-01-2007, 16:43
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
How many lights do you need to put in the box? We only have 4. The drawing shows putting 8 lights in it.
Some kid last year thought the lights were to make the robot look like a low rider.
Brian
Unread 16-01-2007, 17:12
AKA: Carmel Barak
there should be 8 light, in 4 boxes (2 in each, duh)
LighTeam #1957
Unread 16-01-2007, 21:53
Daru Daru is offline
Daru has a spectacular aura aboutDaru has a spectacular aura about
We just velcro'd the CC's to a block of wood. Used a peice of black plastic (The 80/20 stuff) as the back, and used the wood as standoffs for the lights. Then I used standoffs (similar to those in your computer holding the motherboard, but longer) to hold the HDPE lens away from the CCs. It's pleanty bright, the camera sees it fine. No alum. foil involved
Green light same color as overhead light Ethulin Programming 13 02-08-2007 15:24
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
KOP green light 987HighRoller Kit & Additional Hardware 1 13-07-2006 23:18
pic: Green Light Dermot_135 Extra Discussion 17 19-01-2006 18:02
Green Light Rachika Garcia Kit & Additional Hardware 1 10-01-2006 08:46
