Go to Post "there are two types of underprivileged teams; the ones who whine about being underprivileged and the ones that work to become privileged". - Undertones [more]
Unread 16-01-2007, 15:27
itsme itsme is offline
FRC #2217 (FOMH)
Rookie Year: 2007
itsme is an unknown quantity at this point
Quetion about servo tracking function in easyC pro
What does it exactly do? From my understandings it tracks the target (the centroid of the target) by moving the pan and tilt servos. But how do I tell it on witch port the servos are?
Unread 16-01-2007, 15:44
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: Quetion about servo tracking function in easyC pro
Are you referring to the kickoff demo code? There are constants defined in there for the pan/tilt servo ports. The default I believe is 10 for pan, and 11 for tilt. Hit F6 to see a list of macros and constants.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 16-01-2007, 16:08
FRC #2217 (FOMH)
Rookie Year: 2007
I was talking about the built-in function called: servo tracking.
BTW, in the kick-off demo it moves the servos too? I thought it only gives data about the target, and doesn't move anything.
Unread 16-01-2007, 16:17
MattD's Avatar
IIRC, the kickoff demo code doesn't have anything built in for searching, but it does adjust the pan and tilt to stay centered on the target when it is acquired. The functions that do this I believe are called DistanceToPeg() and RotateToPeg().
I may be wrong here, but I think the built-in servo tracking functions require the servos to be connected to the camera board, and this isn't possible with the 2007 camera.
Unread 31-01-2007, 11:09
teekon's Avatar
teekon teekon is offline
Programming?
AKA: Tzyler
FRC #1887 (Russet Robotics)
teekon is an unknown quantity at this point
Exclamation Re: Quetion about servo tracking function in easyC pro
I have my camera plugged into ports 10 and 11 for pan and tilt but it isnt working correctly. The camera will tilt to the ceiling or pan left until it stops and then it just sits there doing nothing.. is there something that has to be changed or should it work??
--ty--
Unread 31-01-2007, 11:30
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
--ty--
Is there anything else in the code that might be affecting pwms 10 and 11? If you were using the C18 compiler and the FIRST-provided code, I'd advise you to check especially Default_routine(), but I don't know enough about EasyC to ask you anything more.
easyC PRO Tutorial - Including the Camera Kingofl337 Programming 4 21-08-2007 16:32
easyC PRO on Ubuntu Linux MattD Programming 5 10-04-2007 19:31
Question about default camera data table in easyC pro itsme Programming 1 16-01-2007 13:57
Additional easyC Pro License Dung H Cao Programming 2 10-01-2007 14:45
pic: easyC PRO at work! Jessica Boucher Extra Discussion 12 14-12-2006 15:25
