Go to Post ...he's acting like a programmer whose code is compiling...:yikes: - EricH [more]
Unread 16-01-2007, 18:13
114Klutz 114Klutz is offline
AKA: Li Pi
FRC #2984 (Viking Robotics)
114Klutz is a jewel in the rough114Klutz is a jewel in the rough114Klutz is a jewel in the rough
Send a message via AIM to 114Klutz
CMUCam over programming port problems..
Here's my current configuration - I have the CMUCam2 connected to the programming port with a M/M Serial Cable. Over the TTL connection it works perfectly, however, over the programming port, it doesn't. The servos center, the lights are on, both of them, on the CMUCam2. This is normally indicative of no camera signal.
I connected the programming port to my laptop, and ran a terminal program. I repeatedly received the CR?>, which I assume to mean camera ready? message. I am not receiving anything else, such as printf debug messages; so that can not be the cause of failure. I have tested the camera over the serial port with the java application, it also works fine.
I'm out of places to look, I reset the robot controller multiple times, and the voltage on the backup battery was 8.2 volts. I went through the FAQ already.
Unread 16-01-2007, 18:22
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Re: CMUCam over programming port problems..
Did you change the serial port the camera code is using?
Is the terminal serial port the same as the camera?
Eric Haskins KC9JVH
Unread 16-01-2007, 18:27
AKA: Li Pi
Yes - I changed the code. I am getting the CR?> message over the programming port.
The camera is plugged into the programming port. I unplugged it, and hooked my laptop to the port to use as a terminal.
Unread 16-01-2007, 18:38
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
If you want, zip-up your code and send it to me and I'll have a quick look this evening.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 16-01-2007, 20:03
FRC #2429
I had a look at your code and didn't see anything obvious related to the camera. My guess is that you're using a straight through serial cable when a null-modem cable is needed. If you can, reverse pins 2 and 3. Also, in your timer ISR, make sure that you also check the timer interrupt enable too. It should look something like this:
else if (PIR1bits.TMR1IF && PIE1bits.TMR1IE)
Let me know if it's not the cable.
-Kevin
Kevin Watson
http://kevin.org
Unread 17-01-2007, 21:48
AKA: Li Pi
That fixed it - thanks.
Programming for CMUCam teh_pwnerer795 Programming 6 25-12-2006 00:23
CMUCam TTL problems gabrielse Programming 4 13-02-2006 14:07
COM port settings for CMUcam labview testing and programming pwilczynski Programming 1 15-01-2006 15:09
CMUcam 2 problems KChampion Programming 1 07-06-2005 10:39
CMUcam autonomous programming kshot Programming 1 17-01-2005 19:18
