Go to Post Underwater basket weaving -- it's a water game, and we can go from "STEM" to "STEAM." - michael.saxon [more]
Unread 17-01-2007, 00:02
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Camera Pan Angle Problem
I zero'd out our camera servos by setting them to the default pan and tilt PWM values as per Kevin's default cam code, then built the camera around them. The code says that the camera should pan within about a 130 degree angle (+/- 65 from center), though ours goes only about 80 (+/- 40).
It's really disadvantageous as the camera loses the light very easily off to the sides with this small range. We'd really like to see it get the full range of motion. Any ideas?
What place are we at? ... TODAI!
pan/tilt connection for 2007 camera kasemodz Programming 5 21-01-2007 14:21
Camera angle - interesting question TEAM1949 Programming 3 08-02-2006 22:20
White Paper Discuss: Assembly of the 2006 pan/tilt camera mount Justin Stiltner Extra Discussion 2 09-01-2006 11:17
Viewing Angle of Camera Joe Johnson Technical Discussion 10 14-01-2005 14:11
Webcast camera angle... Joe Johnson Regional Competitions 13 11-03-2002 16:35
