Go to Post The closest and strongest friendships that I have formed, however, have come from the FIRST robotics program. Friends that I can call “brother,” that I can call “sister,” that I can just call “family.” - DanDon [more]
Unread 17-01-2007, 06:54
Lablabla Lablabla is offline
AKA: Carmel Barak
FRC #1957 (LighTeam)
Lablabla is an unknown quantity at this point
Motor control problem
Hi
we placed the motor in the middle of the chassi,
and we got them working forward and backward. but when we turn, they turn the wrong way (i.e joystick left-> bot right and vice versa)
any thoughts on that?
LighTeam #1957
2006 GM/Technion Israel Regional Finalist (Robot: W.Bob)
Attending: Israel GM\Technion Regional (Robot: Laika)
Unread 17-01-2007, 07:14
Billfred's Avatar
Billfred Billfred is online now
Re: Motor control problem
Originally Posted by Lablabla View Post
Hi
Does the robot still go forwards and backwards correctly? Are you using one-joystick code or two-joystick code?
Unread 17-01-2007, 07:15
jcatt's Avatar
jcatt jcatt is offline
AKA: Jonathan Catt
FRC #1902 (Exploading Bacon and FRC #1251 TechTigers)
jcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of light
One question. How many joysticks are you using to control the robot?
If you are using just one joystick, and programming to control both sides. You can either reverse the pwm's on the controller. Or change in the program.
If you are using two joysticks then you should be using one joystick per side and again just reverse the pwm's on the controller.
Jonathan Catt
Co-Owner and Systems Architect of ColorScene Inc.
Co-Sponsor of The RoboShow: Orlando
FRC 1251 Alumni
FRC 1902 Mentor
Unread 17-01-2007, 15:27
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Rookie Year: 2007
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
If I'm not mistaken, our team had the same problem. You just put the opposite PWM's on the Victors. Try playing with the pwm cables untill it all works(that's how it worked for us :S)
Control Problem SPARKY1688 Programming 2 08-02-2006 01:11
Motor Control Systems Astronouth7303 Programming 3 05-04-2005 19:35
Four motor control judson Programming 1 14-02-2005 20:17
Single joystick control problem Mr. Van Programming 7 23-11-2004 09:10
Motor Control archiver 2000 1 23-06-2002 23:01
