Go to Post How many FIRSTers would quit if they found it was bad for them? I think most FIRSTaholics are thirteen steppers ;) - phrontist [more]
Unread 17-01-2007, 13:12
DylanRoss DylanRoss is offline
FRC #1987
DylanRoss is an unknown quantity at this point
Axes in Default Code?
Hi, I've been looking over the 2007 default code and making adjustments where necessary; however, I've encountered something that doesn't seem right to me. Under the one-joystick drive section, I see this code:
p1_x = 255 - p1_y;
p1_y = 255 - pwm05;
pwm13 = pwm14 = Limit_Mix(2000 + p1_y + p1_x - 127);
pwm15 = pwm16 = Limit_Mix(2000 + p1_y - p1_x + 127);
I haven't actually downloaded the code to the robot, but it seems like the first two lines would switch the X and Y axes. I made a simple program that allowed me to input joystick values and it gave me the right/left drive values, and it gave me the backwards output I expected. It seems to me like removing those first two lines should solve the problem. Is this normal? Are the axes switched? Should I go ahead and remove those two lines?
Thanks,
Dylan
Modified default code gives "code violation" scottmso Programming 8 10-02-2006 23:17
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
user code to default code phoenixomega001 Programming 5 09-01-2005 00:09
Inserting Naviagation code into Default code? actorindp Programming 3 28-01-2004 18:12
default code archiver 2001 2 23-06-2002 22:53
