Go to Post We should have a 'Steps Taken For FIRST' contest. Everyone wear a pedometer and keep a log of how many miles you walked at the St. Louis Championship. That could be a lot of fun. Do they make pedometers for robot carts? - JaneYoung [more]
Unread 17-01-2007, 16:12
stc7790's Avatar
stc7790 stc7790 is offline
Sean a.k.a. SmartKid
FRC #2180 (Zero Gravity)
Team Role: Leadership
Rookie Year: 2007
stc7790 is an unknown quantity at this point
Send a message via AIM to stc7790
Exclamation Sprocket supplyer
does any one know were i can buy sprockets that match the the two sets provided in the kit of parts
Unread 17-01-2007, 16:21
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: Sprocket supplyer
ifi robotics sells #35 which comes in the kit and andy mark sells #35 and #25 sprockets.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 17-01-2007, 16:24
stc7790's Avatar
Rookie Year: 2007
do you know were on the ifi robotics site it is because i still cant find the 21 tooth output sprocket.
Unread 17-01-2007, 17:01
AJ R's Avatar
RoboGeek
The tips and good practices has a list of suppliers and IDG also supplied sprockets. http://www.idglink.com
AJ
Unread 17-01-2007, 17:07
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
I like these guys, http://www.martinsprocket.com/, They have gears and those things too.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Sprocket FRC1710 Rules/Strategy 5 25-01-2006 03:08
sprocket help katkana Technical Discussion 7 21-02-2005 17:23
Chain to Sprocket Daniel Brim Inventor 1 22-01-2004 13:15
I-sprocket? Daniel Brim Inventor 7 21-01-2004 19:26
