Go to Post GP is an ideal to live by, but not a tool to judge with. - Rich Kressly [more]
Unread 17-01-2007, 16:45
riku84kills riku84kills is offline
FRC #2220 (Blue Twilight)
riku84kills is an unknown quantity at this point
access error
Hi,
When I start up Mplab on my school's laptop it load for a little bit and then it displays "access denied" then ends mplab.
I'm just wondering if the account I am using have to be an admin because I’m using a 'student account' on it
also my os is Window XP professional
Unread 17-01-2007, 16:49
ida_noeman's Avatar
ida_noeman ida_noeman is offline
AKA: phobbs
FRC #1719 (Umbrella Corp.)
Team Role: Mechanical
ida_noeman is on a distinguished road
Re: access error
I know for a fact that you don't have to be an admin to run mplab. Are you sure that it is already installed?
If it is, there is nothing you can do but contact your IT department.
"Weeks of coding can save you hours of planning"
"If the code was hard to write, I'm dam well going to make it hard to read!"
Unread 17-01-2007, 16:53
Re: access error
Yes i'm sure it's installed and when IT check on the admin account it worked
Unread 17-01-2007, 16:57
ida_noeman's Avatar
AKA: phobbs
Re: access error
Show them that it doesn't work. They probably set the permissions for the program wrong.
Unread 17-01-2007, 17:01
Re: access error
I'll talk to them about that then
Unread 17-01-2007, 17:23
bobmonkey836's Avatar
bobmonkey836 bobmonkey836 is offline
BobMonkey07
AKA: Jeff Powers
FRC #0836 (Robobees)
bobmonkey836 is on a distinguished road
Re: access error
that pretty definately sounds like a permission issue. the tech people for my school have mostly lightened up on programs, partly because students kept ignoring the blocks, and mostly let anything run.
Solution to life's problems: "CTRL", "ALT", "DELETE".
"CTRL"+"Z" Saved my life.
Approximately Normal
2007 Annapolis Regional at USNA!!
Management is doing things right; leadership is doing the right things.
- Peter Drucker
C18 v2.4 -- Syntax error where there is no syntax error Joel J Programming 7 12-01-2007 17:27
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
Pictures in MS Access Lindsey Scouting 4 19-05-2003 09:08
Wi-Fi access @ Manchester? MattK Regional Competitions 2 06-02-2003 23:41
