Using other pneumatic tubing
I cannot find anywhere in the robot rules, pneumatics manual, or the hints documents, a line that says we MUST use the tubing provided. They do make a point of specifying other items, but not the tubing. I'm not even sure if it's implied.
From an engineering standpoint, I understand the safety aspects of why they want the specific air tanks, safety valve, gauges, regulators, and cylinders. Having a higher diameter tubing to decrease air delivery time (not for more storage) would make sense from a system control standpoint. I was wondering what the forum thought of using 3/8 OD pneumatic tubing instead of the 1/8 tubing supplied. I have a spool of the stuff available, it is COTS, and has a higher air handling capacity than the 1/8" provided. I suppose my specific question is: Can we use 3/8" OD pneumatic tubing (COTS) along with associated 3/8" fittings from the McMaster Carr catalog so long as they interface properly with the Clippard air tanks, the FIRST supplied compressors, regulators, and the Bimba cylinders? Looking forward to some opinions or enlightenment. Regards, Steve Rugoletti srugoletti@timberlanehs.com Timberlane High School, Team 350 Plaistow, NH |
Re: Using other pneumatic tubing
Thank you for the reply. I had read that and was hung up on the meaning of "functionally equivalent." I was wondering if the "functionally equivalent" applied to the "function of the part - as tubing" or as "function of the part - regarding performance." 3/8 will deliver more than twice the flow volume of 1/8, which would have been a real advantage in speed of cylinder deployment.
Thanks for the help in interpreting the rule! Steve Rugoletti co-advisor Team 350 Timberlane High School, Plaistow, NH |
Im not sure, about the pneumatic tubing your talking about i will have to look into it.
| problems with pneumatic tubing in telescoping arm | johnnymac4545 | Pneumatics | 5 | 25-02-2005 11:19 |
| Not using your pneumatic order?? | jjv | General Forum | 0 | 18-02-2004 08:36 |
| Pneumatic Tubing Question | Ryan Dognaux | Pneumatics | 2 | 31-01-2004 20:23 |
| Anyone using other tools? | djcapelis | 3D Animation and Competition | 43 | 21-11-2003 15:50 |
| Can you use other tubing? | Skabana159 | Pneumatics | 2 | 06-02-2003 22:04 |
